hey all ive been lookin around for some kart tracks and i just wanted to see what everybody thought was the best.
i kno of eastern creek, Kartatak raceway in arnclif there was one at sutherland but i think that moved or died.. (havnt gone there in age's) and another one in picton
who has been here, where have u been ? good prices? fun track?
cheers dean
https://www.sau.com.au/forums/topic/208660-go-karting/
There is one in Minto all outdoor and cheap and is great fun in the rain :)
Some of us SAUers are going Go-Karting @Picton on the 29th of March, anyone is welcome so do come along :D
http://www.skylinesaustralia.com/forums/So...ee-t201335.html
https://www.sau.com.au/forums/topic/208660-go-karting/#findComment-3689655
First time was for drifting... THEN it was for breaking the steering arm...
But where the two connected? Too much opposite lock? :thumbsup:
Kembla Grange was awesome! I would go back, even if we where told not to drift. I do admit though, my times where alot faster on the 2nd run because I stopped drifting :cheers:
https://www.sau.com.au/forums/topic/208660-go-karting/#findComment-3694803
there is also a new one at 9 Fitzpatrick St, Revesby, with some weird karts... could be good??
http://indykarts.com.au/
i usually go out to picton and take my own kart for the day. 35 bucks for all the time you'll ever need
Edited by Angus Smart
https://www.sau.com.au/forums/topic/208660-go-karting/#findComment-3733025
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
