have for sale these two items
- R33 GTS-T airbox plus snorkel. comes with new paper filter. is in excellent condition and is almost like new!!
$100 + $20 postage
- R34 GT-T SMIC, in good condition, comes with plastic shroud aswell
$200 + $20 postage
these prices are firm
located on the gold coast
please email on [email protected]
please dont post here as i dont often check here, just email me on the above address.
ill get pics up as soon as i get a chance
https://www.sau.com.au/forums/topic/208667-r33-airbox-plus-r34-gt-t-smic/
  • 1 year later...
Hi, Sorry to bring up and old thread but I still have these lying around my garage
R34 SMIC - $150 + $20 postage
R33 GTS-T airbox plus snorkel - $75 + $20 postage
I dont often check this website so please call 0419650812 if interested.
Located on the Gold Coast
Edited by G4orce
    • Do the R32s run high or low impedance injectors?
    • It may not feel like it to your wallet....but sounds like this was one of those "lucky you did it" rebuilds. Hopefully you have better luck this time
    • It's aftermarket. It also reeks of Honda Civic tryhard from 2003. But if you want one....then you want one.
    • Well some mostly good news and some slight bad news.  Good news is cylinder 6 did in fact only require a honing and I'm good to run my 86.5mm pistons again. I should also get the block back by end of week. Bad news, had a few surprises pop up. First, main and rod bearings were trashed. No sign of any heat damage. I knew right away what caused this... I had not packed my oil pump originally and spent a lot more time than I would have liked cranking the motor to get oil pressure. It sounded fine once started so I chucked it up to luck and forgot about it. Luckily rod and crank are fine and just need new bearings. Engine builder agreed that this was the cause.    Another surprise that carbon covered up very well that I didn't catch, something got sucked up and went through cylinder 1, 2 and 3. Luckily this was no cause for concern, just needed a bit of cleaning up. Valves look fine but he will vacuum test the head this week to confirm. I'm presuming this was something left over from welding my intercooler piping, but we'll never know. I'm going to thoroughly reclean everything.    So all in all, happy the motor is fine, and I'll get it back much sooner than expected. I'll also be taking the time to convert my WMI system over to direct port. I'll snap some pictures of that when the parts come in.
    • I understand, thanks. Yeah I wouldn't want the car to tip over, I'll try and use the sills, I don't want to risk smashing the chassis rails. I ordered some rubber pucks that have a hopefully big enough slotting. If the front right gives me trouble I can always just make a wood block. I'll measure and inspect the sills closer once I actually take the car up. I hope so, but the rubber blocks I had in hand so far were pretty damn firm, if they are that hard they won't give much way. I'll let you know what happens. Angle grinding rubber isn't one of my favorite tasks. I'll probably start a build thread soon, for my own documentation and "log" as well as sharing what's going on with the car.
