[group Buy] Acpt Carbon Fibre Tailshafts Any Model! $1400us
  • Replies 717
OK
My shafts haven't arrived yet.
The photo's attached are of the ACPT Carbon shaft.
I was sent these pic's and the shaft comes with all of the new adapters and fittings as confirmed by JAMES of APCT.
Addvantages:
  • one piece design
  • stronger shaft and fittings to match
  • but still flexes and therefore will transmits less shock loads to the gearbox and diff
  • approximatly half the weigth of the std. steel shafts, this lighter recipricating mass will provide better revibility and response (everyone, that has fitted one, swears by them)
cheers Phil.
post-3052-1207191259_thumb.jpgpost-3052-1207191288_thumb.jpgpost-3052-1207191300_thumb.jpgpost-3052-1207191336_thumb.jpgpost-3052-1207191419_thumb.jpgpost-3052-1207191440_thumb.jpgpost-3052-1207191472_thumb.jpgpost-3052-1207191526_thumb.jpg
Edited by GTR STI
Thanks for posting those photos Phil...
Looks like a carbon sleeved metal shaft. I'm still interested.
its not made of metal,
but think about it.. you cant have carbon joints can you? so there is two metal ends on a carbon shaft.
now if your wondering about reliability... some very very fast drag cars use these shafts in the uk and do not have problems..
you dont have an exact weight for one these do you ? as i have been looking at the TORQline shafts they are 5.9kg but for the price of these they are very tempting
they are pretty much the same weight. 5-6kg's
Have other ppl on SAU used these brand prop shafts?
How much power do they run?
How long have they had them in?
What motorsport do they do?
Depending on answers - add me to the list.
There are many people running these shafts,
i cant quiet get the sepcs on it but i think the mines r34 uses acpt made shaft,
Trust/Hks and alot of big tuning shops in japan sell re branded acpt shafts,
Acpt supplied nismo for the r34 Ztune.
is that enough for you?
You can also find Justin Fox on the forum and ask him about the one he's using.
With a few more people this can be underway!
Cheers
Andrew
Edited by Angus Smart
Indy from IS Motor Racing fitted my one. When we fitted it up there was a situation where we weren't sure if it fit right or not. A quick email (with pics) to and fro between myself and ACPT and all was sorted (all we had to do was have faith and tighten up the main bolts all the way).
I can't tell if the shaft made any difference to the car as I got a whole lot of modifications done at the same time.
Some pictures:
Greenline list a TRUST ACPT CARBON SHAFT, 7.4kg (normal 14.9kg) rated to 14000rpm and 350+km/hr, that looks like the one in Justins pics.
(edit; it looks like the one posted by GTR STI, with a sort of ribbed appearance and a resin type colour, whilst justins one looks black and doesnt appear ribbed. can anyone explain why they look different?)
If this is the same shaft as your group buy, then count me IN.
The best part is that greenline lists it at AUD $3750, or USD $3550, which makes the group buy seem extremely attractive.
Edited by SLY33
They are all acpt, i think that photo phil posted is a common one they send out as i have seen them on the uk forum also..
And a reminder, for an extra 100us you can get a shaft that will handle 2000ft pounds of torque compared to the 1400us 1000ft pounds..
As for payment, as soon as i can get 10 people confirmed i will start collecting money to get it off to james as acpt!
Cheers
Andrew
    • What could be causing my clutch problem besides a bad master or slave then? Both those parts are new
    • Just came across this, but in QLD I start leave again in 2 weeks, if it is still available I might drive up and check it out Unless, @MBS206 do you live near here????, if so I could hit you up with a finders fee https://www.gumtree.com.au/s-ad/hope-island/auto-body-parts/nc-mx5-factory-hard-top/1328976391
    • My hold point for future mods is that I want a OEM detachable hard top first, but, finding one is a pain, MX5 Mania are looking for one for me, but, as hens teeth are more common, finding one in Australia is proving problematic  I can get a OEM one from overseas, hell, you can still get new ones in 'Merica, but, shipping is a absolute killer and I cannot justify the cost, or the risk of it being damaged during transport As for the aftermarket hardtops, whilst they do the job of being a hard top, and are fine for a track car, they don't seal well (read: leak like a sieve in the rain), and you need a plastic/poly rear window, plus they are a bolt in option only and not made to be easily removed I liked how the hard top on my NB could be fitted, and removed, by myself, in less than 5 minutes I know it sounds bad, but I'm waiting for someone to write off a car with one so I can swoop in on their pain, it will go to a good home though, so my guilt of this is tempered
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
