[group Buy] Acpt Carbon Fibre Tailshafts Any Model! $1400us
  • Replies 717
...or maybe not. I'm sure Andrew will give us a delivery date shortly.
yerrrp, all is going ahead, i'm still awaiting a reply, hes had computer troubles and not been able to check his email. but called me today!
honestly im not too fussed if its here on time or not. the car has to go back for tuning oil changes etc anyways.
And time isnt really an issue. a shaft isnt really a hard thing to change, and i myself will be waiting and trying the car before and after installing the shaft. so i can actually see how much more power 2bar does through a set of n1's
i'm excited! the bank isnt..
hi Andrew,
what time frame do you think we are looking at, and did the bloke understand the boys measurements/diagram...
Hey, still not sure as his computer was down and some of my emails haven't been answered yet.
he did however get your diagram and i would think he will get back to me very soon about it!
as for what Russel has said i think i understand now!
the part i have circled moves in and out!! so its length can be compensated thru movement!
my guess is they will make yours correct at the right length!
Ok, no problemo. Just remember it is basically a standard R34 GTR tail shaft plus 24mm... So if they can go by the length of the standard shaft and add the extra length via carbon not spacer it would be fine.
guys,
not part of the group buy as i live in Dubai but my shaft just arrived so i will give you some feed back on the fit when i get around to it.
guys,
Sweeet let us all know how it goes!!
YESSSSSSSSSSS bugga
now they want Fook all to do with it!
Any one want a cheap R33 shaft LOL any way i am sure you guys will be fine.
Hey guys,
Not really an update, but our order is placed @ Acpt,
thats all i really have to report on at the moment!
unsure about wait and time, will let everyone know when its time!
Cheers
Andrew
Thanks for the update Andrew. I didn't realise that was your 32 that got banded up at the Super lap..ouch sorry to see that.
Tacker: the shaft shouldn't be too hard to move on GTROC.UK
Andrew as in me??
    • What could be causing my clutch problem besides a bad master or slave then? Both those parts are new
    • Just came across this, but in QLD I start leave again in 2 weeks, if it is still available I might drive up and check it out Unless, @MBS206 do you live near here????, if so I could hit you up with a finders fee https://www.gumtree.com.au/s-ad/hope-island/auto-body-parts/nc-mx5-factory-hard-top/1328976391
    • My hold point for future mods is that I want a OEM detachable hard top first, but, finding one is a pain, MX5 Mania are looking for one for me, but, as hens teeth are more common, finding one in Australia is proving problematic  I can get a OEM one from overseas, hell, you can still get new ones in 'Merica, but, shipping is a absolute killer and I cannot justify the cost, or the risk of it being damaged during transport As for the aftermarket hardtops, whilst they do the job of being a hard top, and are fine for a track car, they don't seal well (read: leak like a sieve in the rain), and you need a plastic/poly rear window, plus they are a bolt in option only and not made to be easily removed I liked how the hard top on my NB could be fitted, and removed, by myself, in less than 5 minutes I know it sounds bad, but I'm waiting for someone to write off a car with one so I can swoop in on their pain, it will go to a good home though, so my guilt of this is tempered
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
