[group Buy] Acpt Carbon Fibre Tailshafts Any Model! $1400us
  • Replies 717
OK
My shafts haven't arrived yet.
The photo's attached are of the ACPT Carbon shaft.
I was sent these pic's and the shaft comes with all of the new adapters and fittings as confirmed by JAMES of APCT.
Addvantages:
  • one piece design
  • stronger shaft and fittings to match
  • but still flexes and therefore will transmits less shock loads to the gearbox and diff
  • approximatly half the weigth of the std. steel shafts, this lighter recipricating mass will provide better revibility and response (everyone, that has fitted one, swears by them)
cheers Phil.
post-3052-1207191259_thumb.jpgpost-3052-1207191288_thumb.jpgpost-3052-1207191300_thumb.jpgpost-3052-1207191336_thumb.jpgpost-3052-1207191419_thumb.jpgpost-3052-1207191440_thumb.jpgpost-3052-1207191472_thumb.jpgpost-3052-1207191526_thumb.jpg
Edited by GTR STI
Thanks for posting those photos Phil...
Looks like a carbon sleeved metal shaft. I'm still interested.
its not made of metal,
but think about it.. you cant have carbon joints can you? so there is two metal ends on a carbon shaft.
now if your wondering about reliability... some very very fast drag cars use these shafts in the uk and do not have problems..
you dont have an exact weight for one these do you ? as i have been looking at the TORQline shafts they are 5.9kg but for the price of these they are very tempting
they are pretty much the same weight. 5-6kg's
Have other ppl on SAU used these brand prop shafts?
How much power do they run?
How long have they had them in?
What motorsport do they do?
Depending on answers - add me to the list.
There are many people running these shafts,
i cant quiet get the sepcs on it but i think the mines r34 uses acpt made shaft,
Trust/Hks and alot of big tuning shops in japan sell re branded acpt shafts,
Acpt supplied nismo for the r34 Ztune.
is that enough for you?
You can also find Justin Fox on the forum and ask him about the one he's using.
With a few more people this can be underway!
Cheers
Andrew
Edited by Angus Smart
Indy from IS Motor Racing fitted my one. When we fitted it up there was a situation where we weren't sure if it fit right or not. A quick email (with pics) to and fro between myself and ACPT and all was sorted (all we had to do was have faith and tighten up the main bolts all the way).
I can't tell if the shaft made any difference to the car as I got a whole lot of modifications done at the same time.
Some pictures:
Greenline list a TRUST ACPT CARBON SHAFT, 7.4kg (normal 14.9kg) rated to 14000rpm and 350+km/hr, that looks like the one in Justins pics.
(edit; it looks like the one posted by GTR STI, with a sort of ribbed appearance and a resin type colour, whilst justins one looks black and doesnt appear ribbed. can anyone explain why they look different?)
If this is the same shaft as your group buy, then count me IN.
The best part is that greenline lists it at AUD $3750, or USD $3550, which makes the group buy seem extremely attractive.
Edited by SLY33
They are all acpt, i think that photo phil posted is a common one they send out as i have seen them on the uk forum also..
And a reminder, for an extra 100us you can get a shaft that will handle 2000ft pounds of torque compared to the 1400us 1000ft pounds..
As for payment, as soon as i can get 10 people confirmed i will start collecting money to get it off to james as acpt!
Cheers
Andrew
Guest
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
