  • Replies 157
Still laughing at your lame thread. You are the largest noob in the SAU world. It is Christmas, I'm still laughing LOL :laughing-smiley-014:
When will young punks learn? Mods do not add value. I have told you that many times.
LOL LOL LOL!
:O :O :O
LOL LOL LOL!
:D :D :(
I see school holidays are here again.
Have a nice summer Harry, you never know, you might lose your viriginity this year.
On that note people, keep your pets inside, especially hampster owners.
i was checking a nice low klm Autech out at my local import yard and the salesperson proceeded to tell me it was one of only 3 Autech Stagea's in Australia. They also told me it was fitted with all the 'racing gear' and that their father was a racecar driver and had taken it for a drive...his words when he stepped out of the car were "it would be impossible to roll it"...lol...Another sales pitch was that "its been to our mechanic and had the turbo's fixed up"...what a sales person!
LOL LOL LOL!
:D :D :(
Thanks for your input Harry, you are banned.
lol, there would be about 60 of them around now and anything can be rolled, if you try hard enough.
You would like mine Paul, I know you want to buy it.
deal...you buy mine and ill then buy yours
  • 3 weeks later...
hope the ex 14.7psi reads this and i'm sure he will(d/head), congrats on the sale i,m sure you going to miss it, will be able to follow it,s exploits on the stagea forum.
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
