$200 bux cash, for a saturday or sunday, dependin if im working or not,
to install a deck, an dvd player, tv is in already, if u know ur shit shouldnt take more than a couple of hours,
or might even take half an hour, i dont care as long as it wont catch fire when i use it 10months down the track..
call me on 0448 622 516.
a real big thanks chris..
https://www.sau.com.au/forums/topic/208735-who-wants-200-cash/
reason bein guys i would prefer to give sumone on here 200 than leave my car sumwere and find 20 extra km's on the
dash, an all the other the dodgy things the f*ks can do with out ur supervision.. im payin so no probs, just want a good honest job..
the quicker u do it for me the better for u...
10 mins from calder park raceway
an if ur local u can come during the week after 5..
an a quick question, my ground wire sparked when i put it in my amp??
electronics arnt my thing..
If you want it done properly, drop me a PM when you want.
My friend that does Pro Installs lives/works out that way.
He isnt dodgy, wont take your car for a joyride. Paranoia wont get you anywhere in the world
He's worked on maybe 30-40 cars on my referral now, not once complaint ever.
But dont PM me if your gonna go there with the attitude he is dodgy etc, cause i wont send muppets to him :D
Cheers.
chris mate, know exactly how you feel. (EDIT: original poster Chris, not chris above :D)
i got my alarm looked at by Ash's (R31Nismoid) contact, great guy and just cos he was diagnosing a problem he fixed in about 30mins, he didn't even want to charge me! (i insisted i pay) And since then, i've rung him a few times with other alarm related stuff, and he's just helped me straight out over the phone. And even managed to help a total DIY noob like myself get my alarm working again! :D
highly recommend using that contact, you'll definitely get quality work, he really knows his stuff :thumbsup:
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
