So i'm trying to get some quality pics with my Canon S3 IS, but no matter what ISO I use, and what lighting condition, the images always have artefacts or coloured noise in them.
I've got the CHDK firmware mod on it which allows me to run scripts and shoot in RAW mode, so that should cancel the effects of JPG compression artefacts. Regardless of whether or not the hacked firmware is loaded it still gives me similar results.
Here's a blown up look:
Here's the EXIF data:
Full image resized with some noise reduction:
RAW file (converted to Digital Negative DNG file)... right click and save as:
http://www.superfunhappysliders.com/images/CRW_1502.DNG
Does anyone have any ideas on what I'm doing wrong?
https://www.sau.com.au/forums/topic/208755-canon-s3-is-with-artifacts-in-image/
Have you set the compression to fine in the options? About the only thing that I can think off.... Used that very camera for a good while and didn’t have any issues like that... Could also be your pc as it looks like it’s not blending the pixels, when I zoom into my pictures it’s also showing the picture pixelated like that but changes to smooth in about 1 second. My first sugestion would be to try the same pickture on another pc if you haven't yet
Edited by bnr#@
Seems strange, that is definitely a bit too noisy for ISO 75.
*has a look at the DNG*
Alright, I've done a bit of research on you camera. The noise levels you're experiencing are pretty much normal for that sensor. It's small, and noise is a unfortunate result of that.
I believe the S3 IS has noise reduction settings, try them out. A lot of the time though you'll find the noise reduction filters will kill image detail and quality. Software noise reduction options do a pretty good job and might be an option for you in your post processing workflow.
DPReview has some good sample shots from your camera model: http://www.dpreview.com/gallery/Canon_s3IS_samples/
So, you can either live with the noise, fight the noise or buy a new camera. :D
you have taken a photo then tried to crop out a tiny little part of it - maybe 5% of the actual image, and then tried to blow it up big
it is just all pixely
if you printed the original photo at 8x10inch or even 16x20in you wouldnt see that noise
if you just wanted a shot of the grill of the GTR, you should have walked over and taken one, Photoshop cant put detail in that wasnt captured in the original image
the blow up was a chunk to show the amount of colour noise that's in the photos. Usually when you blow up a picture there's blurring or antialiasing, but no colour noise like that. the point I'm trying to make is that the colour noise is quite visible with no zoom applied. Of course I'd take a pic of the grille closer up if that's what I wanted a pic of.
Yeah for 75 ISO on a nice bright outdoor setting that's way too much noise... I'm suspicious that the sensors panel's got something wrong with it.
I turned off the internal noise reduction settings to capture a raw image at full quality and then wanted to do the noise reduction by hand to try and retain as much detail... might try turning it on and see if that's any better. I really wanted to do some macro shots, and that much noise can ruin those kind of shots. Night shots are a nightmare also with all that noise.
having never used an S3IS it may be normal for that model
Canon did issue a recall a while ago for a camera with a CCD problem- i cant remember which model it was though i am currently trying to find out though
my Cameras are a Canon 350d and 1dmk2n - both of which are 8mp DSLRs with a fairly large sensor.
i work for a camera repair facility here in perth and am constantly surprised at what some point and shoot cameras produce.
stuff my colleagues call "normal" from some cameras, wouldnt stay on the memory card for more than a minute or so if i took it with my camera.
Pixel size and density affects image noise.
a large sensor of the same Megapixels as a smaller sensor will nearly always produce cleaner images because of the lower pixel density and lower buildup of heat (the actual cause of the noise) CCD sensors are normally also noisier than CMOS sensors (your camera will have a CCD type sensor)
i am currently downloading the DNG file to have a closer look
EDIT - those pics actually look pretty clean.
i have seen much worse photos come out of some of the cameras at work, and some of the photos that a friend of mine did at my wedding are really noisy, even at 100ISO
a little bit of noise ninja or lightroom's noise reduction and they will look a little better.
and the noise reduction bit in the camera still works with RAW files, it does a dark frame subtraction to long exposures - so even with it on it wouldnt have helped this photo
Edited by Echo63
Like I said, that amount of noise seems pretty normal for that camera (even on those settings). If you want less noise you're going to have to get a new camera (something with a larger sensor -- this usually means less noise).
That seems about right for a camera of that range. If you wanted better you'd prob have to upgrade camera and get something with a better/larger sensor.
Also, comparing the original to the crop you've zoomed in quite alot. Thing is though, even if you had no noise in the crop the pic is still extreemly pixelated so getting rid of it would be of little benifit.
Thats totally normal for a S3 Shan...
Unfortunatlly thats about the best you can do with a CCD, Cmos is the next step in compact digital still cameras, coming next year...
Already great examples in the current DSLR range of what a Cmos sensor can do...
There is also new CMOS technoligy coming to DSLR, with a sensor that has a "gapless micro lens" over each individual diode...
Currentlly on demonstration as the eyes of the Canon HV20 & HG10 HD Camcorders...
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
