with that product do take into account that its designed for different shape licence plates. so the spring tention could be too little.
for rear licence plates ive looked at setting up a air ram or electric solinoid valve for moving that up n down. once ive finished this ill post more. (that could be years knowing me)
My boss told me that you can transmit a certain AM radio frequency that renders a RADAR speed camera (not 3 lines on road) ineffective whilst in range of it. Just a matter of trying it out some how. Older speed cameras that use the 3 lines on the road are not succeptible to such trickery unfortunately.
This technique also works with Porches, by transmitting AM frequencys when your next to a Porche it will shut down its ECU and the driver will have to start the car again. Very effective for drags.
That spray looks pretty good, I had an idea once of putting a high output xenon globe above the number plate that was triggered off by a flash sensitive device...... hopefully in time to blind the camera.
Alternatively you could use solenoids to flip your number plates up and down using a switch inside the car.
So many ideas....... mwaahahahaha ;)
akeenan if you do a good ennuff job of the flippers etc etc then its really going to *** with his head.
most likely get a sticker, but if the plates couldnt be moved when he tried to move then he would be left really confused.
except for the common fact that police browse these forums and are now aware of these devices i think youd be in a bit of trouble.
Guest
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
