with that product do take into account that its designed for different shape licence plates. so the spring tention could be too little.
for rear licence plates ive looked at setting up a air ram or electric solinoid valve for moving that up n down. once ive finished this ill post more. (that could be years knowing me)
My boss told me that you can transmit a certain AM radio frequency that renders a RADAR speed camera (not 3 lines on road) ineffective whilst in range of it. Just a matter of trying it out some how. Older speed cameras that use the 3 lines on the road are not succeptible to such trickery unfortunately.
This technique also works with Porches, by transmitting AM frequencys when your next to a Porche it will shut down its ECU and the driver will have to start the car again. Very effective for drags.
That spray looks pretty good, I had an idea once of putting a high output xenon globe above the number plate that was triggered off by a flash sensitive device...... hopefully in time to blind the camera.
Alternatively you could use solenoids to flip your number plates up and down using a switch inside the car.
So many ideas....... mwaahahahaha ;)
akeenan if you do a good ennuff job of the flippers etc etc then its really going to *** with his head.
most likely get a sticker, but if the plates couldnt be moved when he tried to move then he would be left really confused.
except for the common fact that police browse these forums and are now aware of these devices i think youd be in a bit of trouble.
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
    • Paint is only structural when applied to the outside of Chinese and Indian cars. Otherwise it should never be present between mechanical joints that were intended to be metal to metal. Pain slips, slides, cracks, compresses, and add thickness that wasn't intended to be there. It comes firmly under the category of "just no".
    • appreciated it thanks   There are threads on the adaptor. I rear re anodising but didn’t know it will reduce strength   re mating services needing to be flat/ not painted, why would that be? I am devastated as car been off for a year, fixed power steering then installed bm57 master cylinder and just before driving it this came up. So annoyed   worried and afraid to drive it, no fun caliper coming off
    • Just report the OP (via the 3 dots menu at the top right of post) and request deletion.
    • And boosters can be rebuilt by the same sort of brake shops that will rebuild a brake booster.
