Hey guys, i recently got inspired in the Queensland section when i noticed 1C3B3RG made his cai box with insulation.
http://www.skylinesaustralia.com/forums/Ai...&hl=air+box
Always wanted to do it but didnt have the time, last week i gave it a crack with my old man and it turned out really well, better than we thought.
I went down to Bunnings and got myself 0.5mm aluminum sheet and insulation sheet from Clark rubber.
Got home and made myself a cardboard diagram to make sure i get the right measurements etc. After about 15min of playing with it i got a perfect cut for the side. If you have piping thats similar to my setup you may want to put insulation sheet in the gaps here to reduce the heat coming in. For example:
I then traced it onto the aluminum sheet and cut it away with tin snips.
I also put protective rubber on the edges which u could also get from Clark rubber, just protects it from scratching surroundings and also makes it look neater. Example:
Once it was in and sitting perfect, i sized out the top cover and did the exact same steps. Once that was done i pop riveted them together so it was complete. Then to finish it off i cut out the insulation sheet to the right shape and glued it on with heat resistant glue which i also purchased from Bunnings.
PICS: post-10027-1204538079_thumb.jpg post-10027-1204538092_thumb.jpg post-10027-1204538106_thumb.jpg post-10027-1204538120_thumb.jpg post-10027-1204538142_thumb.jpg
https://www.sau.com.au/forums/topic/208789-my-cai-box/
  • Replies 41
Posted Images
Dam thats pretty tough might give this a try! Could this also hid my boost controller solenoid? Do you guys reckon cops would bother going through it or na! dam i cant wait to do it! Does it actually make a diffrence from the heat?
https://www.sau.com.au/forums/topic/208789-my-cai-box/#findComment-3724546
Thanks guys. Yea its great, Ive just opened my cai to a 100mm hole and my pod is sitting right above it, so its gathering a shit load of cold air. i feel its more responsive in mid range but nothing to dramatic, but its good to know that its sucking cold air from outside and not engine heat.
geraus- if you read through my 1st post it gives a brief way of how i made mine but if u want full details i got mine from the link i provided on the top my page. :nyaanyaa:
RusH_- the rubber edging stuff cost about $7 for a foot at clarks rubber.
R-SPEC- I struggled to find time for mine let alone urs mate, lol. Its very simple though dude, u can do it, just finds some time and dont be lazy, lol.
Cheers,
Steve.
https://www.sau.com.au/forums/topic/208789-my-cai-box/#findComment-3727496
Oh ok man its so good, im still confused and im deciding which way i want to do it, I want to do yours i think! it looks so mad and professional!... I'l try it and tell you guys the outcome.. Thanks so much man! sorry 1 last question which is confusing.. me.. The bunnings warehouse part... So do i go in there and ask for metal? i duno which metal? theres heaps.. ithnk?
https://www.sau.com.au/forums/topic/208789-my-cai-box/#findComment-3728215
Just ask for an Alluminium sheet of 0.5mm thickness. Then you can choose how large you want the sheet to be as they've got cuts already made.
Well done on the effort again Steve :( Very neat and looks professional. I'm changing mine to just the side heat shield - decided not to make a top cover as i can't be bothered. BTW i might need to borrow a drill off ya :)
Cheers,
Steve.
https://www.sau.com.au/forums/topic/208789-my-cai-box/#findComment-3728610
GTS4-32 - thanks dude :)
when u go into bunnings, ask them for "0.5mm aluminium sheeting" they generally have them pre cut to certain sizes, i got one thas about 600mm x 900mm, more than enough cost about $25
edit: damnit, R32 GODZILLA beat me to it :(
Edited by RusH_
https://www.sau.com.au/forums/topic/208789-my-cai-box/#findComment-3728614
MunkybOy- yea i guess itll be a little better but doesnt look all that great. Looks so much better hidden. Still keeps it reasonably cool on the inside though. After a long drive the other day which was like 40degrees, i took the box off and sussed out the heat of the pod and the temp of the inside of the box. The outside of the box was hot but the inside was only slightly warm, not enough to have heat extracting from it though.
https://www.sau.com.au/forums/topic/208789-my-cai-box/#findComment-3728889
    • And if you want more power, more reliably, and cheaper, go get the Aussie RB... The 4L Barra and put that in instead.
    • No cats will keep discolouring the rear bar. Sends white paint a weird yellow stain. Cut and polish normally gets it out, but you'll be doing that every fortnight I found.
    • Both heads will be equally reliable or unreliable depending on what you do to them.  Stock the RB26 head will flow more. You have access to the stock intake ITB manifold on the RB26 cheaply which flows really well(1000hp+).   Arguably more aftermarket support for RB26, though in Aus we love our RB30 SOHC heads too.    The only downsides to the RB26 head is if you have a VL commodore and want to keep the SOHC look.  Where you may have an issue is drilling out the rb30 block for the bigger head studs but if you are building a big power motor you'd probably put bigger studs on the SOHC head too.  This is just about finding a good machine shop, sometimes easier said than done.  RB30 head worked can make big power just like a Rb26 head, so really it actually more comes down to what your preference is for your car.  People now even making billet versions of both.
    • 2630s work perfectly well. There is something to be said for just using the 30 head, as it saves all the pain of the conversion, still makes tons of power, still sounds cool, etc etc. 2630 will obviously make more power again, but the differences are not stupidly big. It really depends on whether you're racing for sheep stations or not. If it's dead serious, then it's a 26 head. If it's just for fun, it could go either way. But the 26 head and the effort to get it set up, etc etc, is part of the fun.
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani Refurbed astra pump thats the cover for it in the boot I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
