How much was the G-Tech and where did u get it from? Methinks I'd like one too :) (just for rough indications) .... I assume with these things you can do the rwkw test then the same day go get a dyno, then calibrate the G-Tech to compensate for any errors? Or are they supposed to be reasonably accurate?
Originally posted by Nightcrawler
How much was the G-Tech and where did u get it from? Methinks I'd like one too :D (just for rough indications) .... I assume with these things you can do the rwkw test then the same day go get a dyno, then calibrate the G-Tech to compensate for any errors? Or are they supposed to be reasonably accurate?
http://www.gtechpro.com/gtechprocomp_howitworks.html
you need to know the weight of the car
I'll show it to you next time
talk more later
wooohooo very good....thanks for the suggestion brute :P
I know and looked after a few ppl in these fields...will bring my car there heheheehhe
I can't wait for the GTECH to get here.
So when does everyone want to go to Mallala? When is a good day for you guys?
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
