UAS are running a track day at Oran Park on SUnday 3 August.
Details are here:
http://www.uniqueautosports.com/Trackday03...rackDayInfo.doc
Application form here:
http://www.uniqueautosports.com/Trackday03...Application.doc
Cost is $195, (+$95 if your wife insists on driving your car as well ;) )
https://www.sau.com.au/forums/topic/20886-uas-oran-park-trackday-sun-3-august/
  • Replies 96
Oran Park is my favourite! 2 reasons, one cause I've only done it at the driver training day and 2, it's a good blend of speed and corners. EC is all speed and Wakefield is all corners.
If there are no spots at EC then I'll be in for this one for sure.
lol! only if you wear a skirt bitch
we've already got rid of all that kitty litter you know :D
Seriously thoug, we don't hear of that many track days at oran park, so you gotta take the chances. I agree with silver-arrows, its the best track in NSW, great mix of challenges. There is a wall at the last turn onto the straight, but as long as you aren't silly you wont go anywhere near it.
i'll be there to watch as the car wont be on the road then.
A mate did his cams there, and a brand new convertable SAAB rolled it into the wall!!!! OUCH
some nice scratches on their helmets though...lucky that was all
Benm we have 17 and 18 inch used slicks going cheap if helps. P platers yes if half responsible if this is posssible? Just spoke with Geoff from SSS who is bringing his Gibson Motorsports powered R32 GTR which will be a long overdue and hotly contested shoot out with our zed. Will be interesting.
Slicks eh, interesting !
How cheap and how used ? (As in approx how many km or laps would I get at EC with no drifting doing 2:00 laptimes?).
To get RE540 Semi-slicks in 225/60/15 it was going to be like $290ea.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
