Hi all,
Just a quick questions about bov's. Standard bov's are plumback therefore all hoses are attached, but when you install an atmospheric bov you have to block one hose. What would happen if you removed that hose and blocked it on a standard bov?
https://www.sau.com.au/forums/topic/208898-atmospheric-bovs/
it will make the standard bov atmospheric.
i dont know about skylines, but out of boredom i have done this to other cars and it sounds like a weak fanny fart.
worth a try but. it's not going to cost you anything
Good idea not posting this in the main Forced Induction thread... you'd be slain :):cool:
All Skylines, as far as I know.. use BOV's that don't seal 100% They leak constantly through a small hole, to smoothen out response when driving. (clearly as they're leaking back to a point in front of the turbo behind the AFM, this doesn't upset running.
You cannot make the stock BOV work atmo, unless you block that hole up.
But hell, don't listen to me, i had to, 4 yrs ago, try it... hahhaa.
I only made it home by left foot braking, and always applying throttle when doing so...
Lack a GF and need some toosh toosh, then grab a proper atmo bov and tune it to NOT STALL with your bender / PFC / full ECU...
Just say'n
The reason im asking crazy questions is my friend has an atmospheric GFB Mach1 bov and has no stalling issues what so ever, and everyone ive talked to about bov's says if its not plumback then your car will have inconsistant revs resulting in stalling. I wanted to know if the standard bov could act like an atmospheric and make different noises without causing them problems. That way you could have fun without spending extra on a new bov. I wont be doing this just a quiery :cheers:.
Yah, the result isn't consistent. I too, have mates who've run atmo bov's on AFM'd cars just fine, which goes against the war cry :thumbsup:
As long as you can adjust the preload so it doesn't open at idle, it wont stall.
To cure stalling when slowing, ppl raise the idle a little, so the idle solenoid doesn't have to work so hard to catch it.
To cure the pops and flame during hi rpm gear shift, ppl lean out the fuel cells in that area, so leaning all the 0% throttle (vertical / load) cells in the higher rpm changes (horizontal)
Some get it to work, some don't :cheers:
edit: read this post about my experiance... 4 yrs ago eeek
Edited by GeeTR
Even the Datto chased revs without it hooked up. I got myself a GFB stealth FX and can now have it whatever ratio I want atmo or plumb back as long as I have enough air going back to the intake. Works a treat though I usually have it all plumb back cos it draws enough attention as is.
    • 2025 Update PRP RB30 Black and Crank Shipped from Austrailia made it and was sent off to the machine shop. -700 to 800hp Service was done to the Block, which included: Inspection Prep and Black Brace to convert engine to 4wd oil Pan  Crank Fully prepped for 1000hp PRP RB30 timing belt kit w/ ALL options Nitto Pistons Nitto I-Beam Rods Nitto Oil Pump New OEM Nissan RB26 Cylinder Head Shipped Supertech intake and exhaust Valves over-sized Kelford 272 cams Mild Lift Nitto Headgasket All of the machine work is completed and next step is assembly and dropping in the new motor.   Upgrades (Changes) from the previous build: Engine Management - no longer using ECUMasters. Haltech Platinum Pro Turbo - Went from twin HKS 2530s with upgraded wheels to BW362SX-E Fuel - 1000cc injectors to ID1430x Single in tank Walbro 450 to Radium External Surge Tank w/ 2x Walbro 450s     I am looking to be back on the road by the end of summer. Wish me luck! monthly updates should be coming!
    • Realised I never posted this , also I never got a price
    • I'm glad to hear you've joined the SKI club. Spend the Kids Inheritance.
    • I have a VALCON if anyone wants it, I have no idea why you'd want to have VVT specifically broken out of the ECU as opposed to running it off the FCON/whatever standalone you have.
    • Hi Yes we're a bit optimistic we might get something out of sealing up the two pipes of the external wastegate and reactivating the stock one. I believe the orginal stock wastegate was tack welded shut. It doesn't budge and visually looks closed and sealed. The car has noticeably more lag so it could be at least part of the problem, maybe all. It's definately one of the key changes made since last tune. And it's one that's more difficult to fully understand and measure, not like for instance timing or cylinder compression.  Thanks for that feedback, we'll let you know how this progresses. Fingers crossed.   Regards Rob
