Fs: Black R32 Skyline - Custom Paint - Price Drop
FOR SALE:
Reason:I have gone through the import stage and im looking for a 4x4 to get around straddy and moreton island.
Features:
Air Conditioning
Power Steering
Electric windows
HICAS
17" Alloys with Near New Tyres all round(80%)
5 Speed Manual
Exterior:
- Custom Airbrushing Paintwork
- Removed Spoiler & Professional Welding & Repainting
- Vertex Bodykit (Front, Rear and Sides)
- Clean cut and Fit of Cooler central to open front end of Front bar
- 25%Tint All Round
- Custom Licence Plates "RBR32"
Engine:
- HKS Front Mount Intercooler
- FLYN Performance Bleed Valve (boosted only to 10psi)
- Alloy Lightweight Intercooler pipes to suit Cooler
- Brand new Extra Heavy duty battery
- Blitz Catback Exhaust system.
- Mileage: 84500km
- Oil & Filter changed every 5000km (myself)
I have never heard a Skyline exhaust sound quite as unique as this one.
Condition of the car is immaculate bar a bubble on the dash, and one (1) Passenger air vent is broken
The car runs perfect, has no flaws in performance
Contact" 0422 184 997
PRICE: PRICE DROP $11,500 ONO
Edited by Benno-
  • 4 weeks later...
hey i have already dropped the price around 3 grand since when i first put it up. i cant go any lower than 11500 or else i will be out of pocket when i get my next car...
I actually have it up for $12,500 on carsales so you will save $1000 buying it from SAU.
  • 3 weeks later...
  • 5 weeks later...
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
