Has anyone got any idea why my car won't launch. There are no fault lights coming on in my dash And the 4wd seems to work a little when im driving it hard, but when I try and do a launch it spins the wheels through most of 1st gear and slowly takes off. The highest i've seen my torque meter go is around 20 to 30 %. When you do a launch shouldn't the torque meter hit 50% please help.
https://www.sau.com.au/forums/topic/208933-cant-do-a-launch/
Make sure the atessa system is bled and you have fluid in the reservoir in the boot. Do a search in the forums here on info on how to bleed the system.
Jack the car up on stands so that all the wheels are off the ground and put it in 1st and let it idle. Should spin all 4. If you don't think it is applying all 50% then pull the front drive shaft and do the same. When the rears spin but the fronts don't the Atessa should try to do 50% reading on the gauge. I just did that with mine tonight to diagnose my diff problem.
I'm having Atessa problems myself, but I hope for your sake your problem isn't as bad as mine. Mine appears to be the front diff is shot.
Hope that helps.
well the gauge doesn't get to 50% it doesn't read a %at all (kg/m or something, I can't remember).
but anyway, if the 4wd light is not on, and 4wd doesn't seem to be working it is most likely a transfer case problem....(eric is special, and lucky). You could try his test that should tell you if the fronts are getting any power. if they aren't pull the line off the back of the gearbox (car still on stands) and start the car - should pump fluid out pretty rapidly. if not the pump is farked.
Hope that helps.
Thanks pez In my car I am getting some power to the front I can feel the car pull it self out of wheel spin when I rev out 1st gear and do a hard change to 2nd. Also when I take a corner quickly and it steps out it I can feel the steering wheel stiffen up as the car pulls it self out of oversteer,but I only have had a max of 30 % come up on my torque meter. The problem is it takes a very long time to pull it self out of wheel spin when i do a 1st gear launch. I,ve tried bleeding the system, do you know where the bleed point is at the back of the car on a r34 gtr? Is it on the pump itelf?
It'll only apply as much as it thinks it needs.
Have you got good rubber? What clutch? How much power? If I launch mine it'll also spin all the way through first... but I do see 50% on the meter, and it's just power with an aggressive clutch thats making it spin.
If its power making it spin u should be spining all 4 wheels through first gear. Mine is only spining the rears I got new tyres on it stock power. Does anyone know a work shop in perth that can fix the attesa system?
    • I would like to add that at least in my car, the RPM gauge shows around 200RPM above of what I can see at nistune.
    • Unless you have big cams, there is no reason for an RB to idle at any more than the stock 650. No, it is not 850, 950, or anything else. It is 650. In fact, it might even be 550. I just opened an arbitrary stock Neo file in Nistune, and this is what I see
    • I love the undertray, especially the flappy bit for easier access for serving I'm thinking of fabing up one at work for the MX5 while I still have access to the metal shop at work with a guillotine and press brake Whilst removing the plastic undertray on the MX5 isn't to hard, I love the idea of a 2 bolt flap as opposed to removing the whole thing
    • Great thank you for that. Yeah that is the bumper and spoiler it still has i just hadn't heard of it being referred to as a aero form bumper before. Really appreciate your help.
    • A little progress; I took the opportunity of an oil change to take a sample for oil analysis, will be interesting to see how it was treated for its first 125,000klm (I know how it has been treated since :rofl:) I went with 5w40 and will see what that does for oil pressure at higher revs. Also fitted the Z1 front undertray....a little more sturdy than the plastic factory one (although I suspect it won't stop a tree stump ) Nicest thing about it really is the 2 bolt "service panel"....a gift to the oil changer compared to removing 14 bolts holding the factory tray.
