I am thinking about drilling a hole through the tweeters covers and running the wire through down the pillar, anyone done this, Also this may see like a silly question but do you need specific output to tweeters from the stereo as mine are not currently working and I though they would just branch off from the front speaker wires?????
Thank Ben
Edited by cefiro
https://www.sau.com.au/forums/topic/208938-boost-gauge-wires-through-tweeters/
I wouldn't go drilling anything just on principle but I assume you could do it, but remember there are the actual speakers to get past with the wires (would there be any 'noise' interference having the wiring so close?)
My boost gauge wire/hose come through the air vent on top of the dash, this leads through a grommet through the firewall too so there was no drilling required.
Your tweeters should work, but I'm no expert, maybe it depends on your head unit?
  • 4 weeks later...
Done:I went through the tweeters and it turned out really well, I think anyway.
Remover Tweeter cover, then get the vac hose through by using a straightened up coat hanger (attached to vac hose) angled to get it into the foot well, then follow with the wires into the same area, and hooked then up to earth and lights. The best way I found to get the vac hose into the engine bay was to poke a hole in the grommet (located just above to the bonnet cable and to the right) by using the coat hanger from the engine bay into under the dash (not visa versa) and then sticky tape the hose onto the coat hanger and pull it into the engine bay. Cut into pressure sender at back on engine and tee in vac hose. I had to cut out the speaker cover and just cut one of the holes which was the perfect size for the vac hose and wires to get through. I hook up vac hose and wires into the gauge and bobs you uncle.
nice
never thought of that
my tweeters are disconnected, and I happen to have the same boost guage, in the same spot but with the lines/wires going up the side of the dash.
will give it a whirl one day
In a normal installation your tweeters should be connected to a small box known as the crossover..This box basically splits the sound between woofer and tweeter...SO the 2 wires that normally wire directly to speakers will go straight to the crossover, from that one pair will go to the woofer, the other pair go to tweeter.....hope that helps
I was reluctant to drill/cut any of my interior so I ran mine up through the weather strip and jammed them under the edge of the a pillar plastics.
Only problem I can see in the future is the boost line eventually pinching closed from the pressure, but its been working fine for a few weeks.
On the topic of boost gauges I fitted one yesterday to the steering column as it's below the top of the steering wheel, it's still easy to read and it's the straightest route for the vacuum line. Am I the only one who's done this?
xmetal mine was like that when I got the car, didnt like it, set it back further into the dash, didint like it, so set it like rubba has.
out of the way (for my 2m height) perfectly, but yet right there.......
getting some overboost with wot. =(
just on the subject. i braught a boost gauge yesterday but it had a copper hose thing for the vacume pipe... how am i going to go connecting that to my stag?
Apparently there's a few vacuum plug somethings on the back of the plenum nearest to the firewall but i've plumbed mine into the front of the plenum running off the Fuel regulator line. Just a warning, make sure all the hoses are secured properly if you do it this way as it could get messy if comes undone and the FPR looses vacuum pressure.
Thats how id be doing it. Looks neater, its out of the way, doesnt attract unwanted attention... im not a fan of dash mounted guages...
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
    • Stock O2 sensors are narrowband. They're useless once you're away from stoich. IE, useless for what you're trying to do. 10:1 will read the same as 14:1 from the stock O2 sensors. That is, they'll read rich. The same level of rich.
    • I agree once misfires happen it's basically worthless, but the hope is you can see what's happening in the run up to that.
    • You should totally get a Brumby, and then come pick up the Subaru Liberty GTB I have here. EJ25 Turbo, 6 speed manual from the sti (just no dccd), and the good rear diff. Drop all that into a Brumby and go have fun!
