Looking for recommendations from the experts
Considering lightly modding my 32 GTR
What is the best route to take
Don't want to go crazy with expensive mods
Considering
N1 turbos
Boost control
Exhaust
Nistune daughterboard ECU
FMIC
Would these mods be worthwhile on a std engine?
Are the N1 turbos a good mod or would setting the std turbos rebuilt be better
Thanks
https://www.sau.com.au/forums/topic/208972-best-way-to-mod-a-gtr/
i would stick to stock because everything on a gtr is expensive LOL, plus the fact you'll always want more.
for a mild modded car (assuming suspension/brakes are not in the equation)
- hi flows / 34gtr /gt-ss turbos
- full exhaust
- air filter
- boost
you should already be pretty happy with that and your wallet should be kept pretty busy too.. i had a mines ecu in my old gtr it ran pretty good with the above mods (i had hiflows).
if you got some more cash left over, you could get some ridiculous power out of the car by adding these:
- cam gears
- power fc
- injectors & fuel pump
hope that helps
I'd go slightly different to above...
- 34N1s /gt-ss turbos
- full exhaust
- air filter
- boost controller
- turbo dumps
- NIStune, or Power FC.
- Cams if your the budget allows.
- New clutch wouldn't go astray if needed...
the standard fmic is good for i think about 300kw
so should be fine
True that!
I suggest:
Twin air pods or panel filter upgrade.
Full exhaust system.
Remove the Boost restrictor (Thats if it hasn't been removed, but 99% it has) for safe factory boost increase.
Boost controller but don't boost it too high or you will need to upgrade internals.
Upgrade suspension (Lower car).
Upgrade brake pads
This should be good for lightly tune GTR.
I would do a full exhaust first. N1's are a great idea. Don't be stingy on dump pipes. Get a reliable boost controller. Yeh as everyone else said about ECU, power FC is a pretty good all-round choice.
If you don't plan on much modding, what you DO do do right.
Sorry for all the do-do's.
yep, good info
our first 10 second pass , was a standard n1 engine straight from just jap with a aftermarketset of cams, ecu, airfilters and pumps and injectors, dumps and exhaust (did have a ppg gearbox though, 11.1's prior to box going in) was running vp 109 fuel though.
still had standard intercooler, standard exhaust manifold and intake setup pipe work .
doing these mods (aftermarketset of cams, ecu, airfilters and pumps and injectors, dumps and exhaust ) can give your more than enough power to start breaking other things & start costing you even more to uprate!! :cheers: & so the cycle begins! hehe
You could get in to the 12 bracket with adding the following to your current mods.
Large hi flow cat - $300?
aftermarket dump pipes and front pipes - $??? really not sure what GTR parts are worth in this department.
remap ecu - $anywhere from $150 - $600
14psi - $free if you remove the restrictor or $40 for a manual turbotech boost controller or from $300 for a brand name EBC.
that should give you something around 250rwkw.
if the clutch is up to it, side step it from 6500rpm and get your shifts right and you'll come back past the timing station with a 12.xx time slip in your hand.
obviously, the above is the cheapest option.
there is always the option to get PFC, top of the line EBC, CES dump and front pipes with seperate wastegate pipe etc etc.
Hi,
I think the Pods being un-sheilded is a quick area to fix, I just used some foam matting and the intake temps on the PFC dropped 10 degrees or more. Or go get the standard airbox.
Once you have an ecu, a set of cams is a great move to beef up the mid range power and enable you to make more power (or the same if you want to keep the old original motor alive longer) with less boost, timing , rpm and less agressive fuel map.
On standard turbos my old car with cams made about 40rwhp more than people get out of adjusted cam gears as low as 3,000rpm. So it's a good mod for a mild worn motor setup.
GT-SS turbos look to be a good size but, smaller varients of the N1 or even stock turbos with steel wheels. I reckon 300rwkw is more than enough if you can fatten up the power band on a stock motor.
Thanks guys
The car already has
Bilstein Suspension
Twin pod filters
Unknown jap cat back exhaust
Compliance cat
Ran a 13.8 400m last week and want into the 12 bracket :banana:
Just go upgraded clutch, boost controller, dump/front pipes and decent launches with good sixty footers and you'll be in the 12s
If you go -5's I would be putting in cams to make best use of them. Otherwise the car is laggier than it has to be for the power you make.
For a stock motor I would go with -7's/gtss +pfc+pressure reg+full good jap exhaust and run 1.1-1.2 bar and be happy with the 280-300rwkw you make. Saves you having to replace afm's, fuel pump, injectors and cams to go the next step.
  • 2 years later...
Hey I just got a 98 gtr vspec with -5s n cat back, once I finish the exshust n do a full remap I hope I get some better power, but my main goal is 350awkw so the hunt for parts begins lol do you think I could break a 11 sec pass??
- full exhaust
- air filter
- boost controller
- turbo dumps
Id go very similar to infamous_t
400rwhp = Hi-flow stock turbos / 34 n1s/ -7s / GT-SS (all around the same HP, but a slight difference in response and price)
500hp range go -5s or 2530s (add injectors too)
Full exhaust
pods
boost controller
cam gears
nistune if your sticking with afm, haltech or vipec with MAP
New clutch is also recommended and your standard cooler will flow close to 500hp
A good launch and no mis-shifts should net a easy 12
PS. start saving for a rebuild too
Edited by R32 Driver
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Right, here's a video of the basic operation at least.  This is what you can expect day to day when you turn the car on and it boots from standby.  The only thing from a media point of view I haven't gotten working is for it to autoplay plexamp when it turns on from standby (it works from cold boot) but that's more of a plexamp problem as it will autoplay other music players.  Also attached is my one stray cable.  It's part of the screen's wiring adapters but there's just nowhere for it to go in my car.  I've just now done a bit of research and found a matching port on a 2010-2014 head unit with BOSE.  Mine has no BOSE so that's that case pretty much closed I think.  Plugging in the Infiniti AC panel basically did nothing for me, so that's a dead end as well.  Next port of call is to mess with this CANBUS module and see what I can find from it.  I found this resource containing the DBC files for a 2010+ G37 : https://github.com/icecube45/Dash_InfinitiG37/blob/master/InfinitiG37.dbc I'll now have something to go from when I try to extract my CANBUS data so I can see if the HVAC Mode, Fan Speed, Temperature, etc. match and also the gear shifter position.  It's a pretty big assumption that it's just mismatched CAN signals but considering all the devices in the CAN network are talking to each other (AC can be fully adjusted just with no info on screen) it might be a safe one.  I will report back WhatsApp Video 2025-02-26 at 12.49.10.mp4
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • As above, you did refill the coolant and burp the system before running it again didn't you?
