Looking for recommendations from the experts
Considering lightly modding my 32 GTR
What is the best route to take
Don't want to go crazy with expensive mods
Considering
N1 turbos
Boost control
Exhaust
Nistune daughterboard ECU
FMIC
Would these mods be worthwhile on a std engine?
Are the N1 turbos a good mod or would setting the std turbos rebuilt be better
Thanks
https://www.sau.com.au/forums/topic/208972-best-way-to-mod-a-gtr/
i would stick to stock because everything on a gtr is expensive LOL, plus the fact you'll always want more.
for a mild modded car (assuming suspension/brakes are not in the equation)
- hi flows / 34gtr /gt-ss turbos
- full exhaust
- air filter
- boost
you should already be pretty happy with that and your wallet should be kept pretty busy too.. i had a mines ecu in my old gtr it ran pretty good with the above mods (i had hiflows).
if you got some more cash left over, you could get some ridiculous power out of the car by adding these:
- cam gears
- power fc
- injectors & fuel pump
hope that helps
I'd go slightly different to above...
- 34N1s /gt-ss turbos
- full exhaust
- air filter
- boost controller
- turbo dumps
- NIStune, or Power FC.
- Cams if your the budget allows.
- New clutch wouldn't go astray if needed...
the standard fmic is good for i think about 300kw
so should be fine
True that!
I suggest:
Twin air pods or panel filter upgrade.
Full exhaust system.
Remove the Boost restrictor (Thats if it hasn't been removed, but 99% it has) for safe factory boost increase.
Boost controller but don't boost it too high or you will need to upgrade internals.
Upgrade suspension (Lower car).
Upgrade brake pads
This should be good for lightly tune GTR.
I would do a full exhaust first. N1's are a great idea. Don't be stingy on dump pipes. Get a reliable boost controller. Yeh as everyone else said about ECU, power FC is a pretty good all-round choice.
If you don't plan on much modding, what you DO do do right.
Sorry for all the do-do's.
yep, good info
our first 10 second pass , was a standard n1 engine straight from just jap with a aftermarketset of cams, ecu, airfilters and pumps and injectors, dumps and exhaust (did have a ppg gearbox though, 11.1's prior to box going in) was running vp 109 fuel though.
still had standard intercooler, standard exhaust manifold and intake setup pipe work .
doing these mods (aftermarketset of cams, ecu, airfilters and pumps and injectors, dumps and exhaust ) can give your more than enough power to start breaking other things & start costing you even more to uprate!! :cheers: & so the cycle begins! hehe
You could get in to the 12 bracket with adding the following to your current mods.
Large hi flow cat - $300?
aftermarket dump pipes and front pipes - $??? really not sure what GTR parts are worth in this department.
remap ecu - $anywhere from $150 - $600
14psi - $free if you remove the restrictor or $40 for a manual turbotech boost controller or from $300 for a brand name EBC.
that should give you something around 250rwkw.
if the clutch is up to it, side step it from 6500rpm and get your shifts right and you'll come back past the timing station with a 12.xx time slip in your hand.
obviously, the above is the cheapest option.
there is always the option to get PFC, top of the line EBC, CES dump and front pipes with seperate wastegate pipe etc etc.
Hi,
I think the Pods being un-sheilded is a quick area to fix, I just used some foam matting and the intake temps on the PFC dropped 10 degrees or more. Or go get the standard airbox.
Once you have an ecu, a set of cams is a great move to beef up the mid range power and enable you to make more power (or the same if you want to keep the old original motor alive longer) with less boost, timing , rpm and less agressive fuel map.
On standard turbos my old car with cams made about 40rwhp more than people get out of adjusted cam gears as low as 3,000rpm. So it's a good mod for a mild worn motor setup.
GT-SS turbos look to be a good size but, smaller varients of the N1 or even stock turbos with steel wheels. I reckon 300rwkw is more than enough if you can fatten up the power band on a stock motor.
Thanks guys
The car already has
Bilstein Suspension
Twin pod filters
Unknown jap cat back exhaust
Compliance cat
Ran a 13.8 400m last week and want into the 12 bracket :banana:
Just go upgraded clutch, boost controller, dump/front pipes and decent launches with good sixty footers and you'll be in the 12s
If you go -5's I would be putting in cams to make best use of them. Otherwise the car is laggier than it has to be for the power you make.
For a stock motor I would go with -7's/gtss +pfc+pressure reg+full good jap exhaust and run 1.1-1.2 bar and be happy with the 280-300rwkw you make. Saves you having to replace afm's, fuel pump, injectors and cams to go the next step.
  • 2 years later...
Hey I just got a 98 gtr vspec with -5s n cat back, once I finish the exshust n do a full remap I hope I get some better power, but my main goal is 350awkw so the hunt for parts begins lol do you think I could break a 11 sec pass??
- full exhaust
- air filter
- boost controller
- turbo dumps
Id go very similar to infamous_t
400rwhp = Hi-flow stock turbos / 34 n1s/ -7s / GT-SS (all around the same HP, but a slight difference in response and price)
500hp range go -5s or 2530s (add injectors too)
Full exhaust
pods
boost controller
cam gears
nistune if your sticking with afm, haltech or vipec with MAP
New clutch is also recommended and your standard cooler will flow close to 500hp
A good launch and no mis-shifts should net a easy 12
PS. start saving for a rebuild too
Edited by R32 Driver
    • Hey Mark...sorry to interrupt your career change to hair dressing... but...did you ever fit the interchiller to the commodore, and if so how was it? And, who made it?
    • I've been pondering this, I really enjoy the convertible thing, for me, it's like riding a motorbike, without all the issue of riding a motorbike, mainly, my old sore arthritic joints getting beaten up, and, being able to do it in shorts and a T-shirt and not needing a helmet and all the other gear required, especially like wearing jackets and pants in the summer, or needing 6 layers of cloths in the winter, or not having wet weather gear handy when your 100km away from home on the bike when it decides to start raining As for the hard top and its Coupe look, whilst I do lose all that open top feeling that I really enjoy, from my experience with the NB with a detachable hard top, the cabin is a much nicer place to be, the difference in noise for one, a hard top quietens down the interior, alot, with the soft top up or down it's pretty noisy, which, after 5 or so hours, can get tiring But, as you stated, the detachable hard top totally changes the look of the car, in a really good way, and for me, the look of a detachable hard top is so much better than the PRHT which looks more like a after thought with its weird bulbous rear roof line For me, the minimal effort of putting in on, or storing it after removing it, is well worth the time and effort for the look alone And yes, I'm sure the next owner will be grateful for it as well.......
    • I get into huffs with people when I suggest the MX5 looks so much better as a coupe than it does as convertible. Pretty sure I don't prefer the convertible version of anything. Good job on the hardtop! The next buyer will appreciate.
    • IMO wrap does have its uses, but like you said, quality wrap, and professional installation, would probably cost want a quality paint job does, but, the paint, if maintained, is basically for life, and much easier to touch up if required  In other news: it's pissing down here, with thunder, lightning and only some small hail "at this stage", luckily all "my" cars are undercover  I've also been contacted by a guy in Newcastle about the SS, he said he will come down next weekend for a look, we'll see how that transpires I guess 🫰
    • Nah, I'm not an a-hole, ha ha!   I do like the colour match. Some of the carbon fibre wraps are quite freaking horrible. There's one a local company I know uses, and it looks damn good! Also very very expensive per metre to buy! ha ha ha It might be cheaper to respray the roof than use the good CF Wrap, ha ha!
