Hey I just got a 98 gtr vspec with -5s n cat back, once I finish the exshust n do a full remap I hope I get some better power, but my main goal is 350awkw so the hunt for parts begins lol do you think I could break a 11 sec pass??
You should be able to do high 11's on the factory turbos (260-270rwkw). R32 GTR's have run mid 11 with the factory items, R34's are a bit heavier so a high 11/low 12
350rwkw you are looking deep 11/high 10's but it all comes down to driving, launch, tyres etc
GT2860-7 or 9's
Nistune or powerfc
panel filter
front pipe
decent cat
injectors if your aiming much over 300kw to BE SAFE, std r32 injectors are getting a big long in the tooth and can leak.
300-330rwkw easy, it kinda the stable mod diet for a R32 or R33 GTR nowadys.
who said -5s are stock turbos?
and how do you define "better"? more power? more responsive?
I think your misinterpreting Dagz's poorly constructed previous post, it actually says I have Garrett -5's which are better than stock turbo's.
I would assume better = more power in this case (and non-ceramic exhaust wheels :) )
Personally I want 2860-9's at some point in this year but I'm not so interested in drag times, more in street/track response where I drive on the street more often than the track :)
Hi mate. I would decide if it is going to be a predominantly street car, or track and street car.
I have a 33 GTR. Initially stock. Put exhaust, filters, removed boost restrictor - was good for 240RWKW. It was awesome for the street, and in my opinion perfect for a daily driver. Lightning response, pleasure to drive every day. On the track though, boost came on super early, but like a light switch, meaning it would get messy if you nailed it coming out of a corner (Im sure this could have been corrected with a power FC and good tune).
Then added 2860-9 turbos, power FC, oil cooler, and cam gears for an easy 280RWKW on a Racepace safe tune. In comparison, it actually feels a little slower on the street. And I emphasise feels. Only because it requires more road to wind up the turbos which are slightly less responsive. On the track it is way way better, boost comes on early but progressively for great control out of corners, with a fat and elastic mid range. Wouldn't push a 32 too much more that this sort of tune unless you budget for a rebuilt in the future.
Cheers,
Luke.
I have a 32 and I bought a pair of -5's but before I install I am going to swap them for a pair of -9's. I think standard engines just can't see the big power that -5 are capable of. As such go for the slightly more responsive turbo, which will give power without stretching a standard motor.
Along with this I have the following
- CES Race pipes (already have 3.5" cat back)
- Larger 4" cat
- Cam Gears
- Power FC and 550cc injectors, Blitz EBC (installed in car for some time now)
- Will get nismo or tomei fuel pump
- A bit of ceramic coating turbine housings and manifolds
Will hopefully see at least 300rwkw at around 1.3bar.
Edited by gtr fan
PS. start saving for a rebuild too
is asking 400rwhp for a street driven(occasional skid pan etc) R34 RB26DETT asking too much from it internally. I am aware the R34 RB26 is the "strongest" of the bunch, but what are its limits?
Is it safe to run a 34R with a exhaust(front pipe, cat, catback) change, pod filters, EBC @ 14 psi WITHOUT any changes to factory computer? for example one wouldnt dare do that to a WRX unless one had a rebuild/new engine on standby :P
Snowman ran 330rwkw for i think 2.5years (lots of circuit/street) and it failed. Only one example though.
You might as well get a PFC mate, for $900 - why not? :P
Factory R34 turbos will only give you around 250rwkw either way - although depends how much of a risk taker you are.
I wouldn't run factory turbos @ 14psi... I would be fearful of turbo death (which leads to motor usually)... so 12psi would be where i'd stop factory turbos.
Yes i realise the above is conservative, but it's better than a dead motor if you dont plan to ever rebuild
    • So now doing the change and first time dealing with rb so little nervous giving engine power and potential for screwing it up When you align all marks and then remove crank bolt, timing move little I assume you can put the bolt back in once you have removed the pully to get timing to where you want?   here is pic of my both intake and exchust cam aligned, depending on angle you look they seem to be either aligned or a half tooth or so out. Any thoughts? Should you angle your face and look at each mark that way as if looking straight rather than from above as it can be misleading   <a href="https://ibb.co/ZpnhcvbF"><img src="https://i.ibb.co/HfWrGR9b/IMG-4447.jpg" alt="IMG-4447" border="0"></a> <a href="https://ibb.co/4wm2wn4q"><img src="https://i.ibb.co/JWBqWwr1/IMG-4445.jpg" alt="IMG-4445" border="0"></a>   https://ibb.co/ZpnhcvbF https://ibb.co/4wm2wn4q
    • Thanks for the reply @GTSBoy Haven't really thought of that yet, but you are right. If the hose was damaged it should be absolutely pissing by now. I'll put some heat sleeve around it for good measure since I'm already removing the line anyway.  Maybe I'll put on some of the stock hardlines if I ever fully remove the turbos again. Maybe when T51R modding the compressor housings? Might be a fun mod on GT28s for that "fake single turbo" effect.
    • Update 1: I did some work on the car already before finalizing this post and my "issues" list. I dropped the Tomei exhaust in favor of the HKS Hi Power Silent. Sounds nice and I can actually hear myself think now. Also gives me a realistic chance to legally drive without silencer inserts. A bit of cheating was necessary to still be able to mount the Top Secret style diffuser. Some malusage of washers and a bit of "convincing" toward the brackets and exhaust hanger seemed to do the trick. The shaky steering wheel has been resolved as various suspension components were worn, like sway bar bushings and link bars. Most notably the two steering tie rod ends. Had some trouble finding bushings because my sway bars are not OEM thickness, 23.x up front and 27 rear. But non adjustable, so no aftermarket I suppose. Maybe they are nismo units? Turbo oil drain hoses were definitely still the originals and are new now. Wasn't the cause of the turbo oil leak sadly. Currently removing the rear turbo because of it, I suspect the braided oil feed line is the culprit. This issue needs to be dealt with so I can work towards actually getting the turbo setup legal and inspected. Two new issues to add to the list as well. Rear Main seal is probably leaking. Time will show how bad it is, I don't really want to drop the gearbox right now just for the stupid seal. Could fix a few other things in one go once I do that. Front right driveshaft grease is going past the cv boot, so at some point I'll fix that too.
    • Ok so no 4cyl clutch... Yeah it is a factory manual. So if iam correct i need clutch and flywheel too? I can use something that suits something like R32 GTST?   EDIT: https://www.ebay.com/itm/224291042776 Is this ok?   EDIT2: i maybe forget to mention this(dk how important it is) but the trans will be behind RB25DET NEO(iam doing swap) It will be there for a little while. Iam planing to do bigbox or BMW tranny..
    • You're probably right about that one. Thanks for your suggestions, I hope I don't need a new 3rd brake light. Although wiring issues might arguably be worse. Right now I'm in the midst of a turbo removal because of my oil leak, other problems are going to have to wait for now.
