Hey all,
In the process of buying some slotted rotors, for obvious reasons...anyway, my stock rotors squeak like a bit**! so before I go buy that anti squeak fluid stuff, I wanna check whether it may be easier just to leave it until the new rotors go on.
The pads were replaced 8 weeks ago, and rotors machined...started squeaking abt 3 weeks ago. performance is still great, but the noise the little b**&ards make is REALLY getting to me.
https://www.sau.com.au/forums/topic/20900-slotted-rotors-do-they-squeak-too/
I recently put 4000 series dba slotted rotors on mine with new pads and the rears still have the loudest, most annoying squeak/squeal. You would never have guessed that I had just spent a grand on the brakes. It sounds like I have no meat left on the pads at all, it is really starting to bug me. I am going to try some anit squeal stuff soon.
hey zaki is it squeakin when u are not applying brake ? i have that problem sumone suggested that i have to rebuild my calipers, but no money right now for that. As for squeal when u brake, usually high performance pads squeal heaps, i kind of like it :)
I used the standard R33 GTS-T S1 rotors for around 15,000km with absolutely no squeal (Bendix Ultimate pads) and i've now put 5,000km on the new DBA 4000 Series Slotted rotors with Bendix Ultimate pads and don't get any squeal.
Actually now that i think of it i do get squeal... after i have washed my car and i reverse down the driveway for the very first time, but after 30m of that its 100% no squeal at any time (not even at a trackday).
i never had squeak at all with my slotted/drilled rotors. Now its started its pretty damn annoying.. could have something to do with alignment as my alignment has been thrown right out now that my tierod is bent..
once its back on the road gotta track down that squeak - 'cause **** its loud.. my pushbike does it too from the brakes on that too and that is annoying as well !
i think it is to do with moisture.. when my car was garaged never a problem.. now i've moved and its outside and condensation forms overnight - now the squeak has begun
Brake squeal is one of those luck of the draw things. Some pads will tend to squeal more than others, but there will always be some people that always get squeal and some that never do with any pad you care to mention. However there is no one with Ultimate pads that doesn't get dust :D
I don't think rebuilding calipers will help with squeal at all, all that will do is provide a more linear amount of pressure on the brake when it is applied, and possibly stop the pads from touching on the disc when in motion. It depends on where the stickiness in the piston lies.
If you want to try a cheapass rebuild, move the piston in and out a few times. To do this pull the caliper off the hub and push the pistons back. Then pump the pedal a couple of times to push them out again (be careful, not too far out!) and push them back in again. I did that with mine along with a fluid flush and the brakes feel like brand new again.
Slots and holes in your rotors will help prevent squeal, but they may not cure it. Again it comes back to the luck of the draw.
Jim, rebuilding the caliper is an unusual way of fixing a squeal... but if the pads are constantly rubbing on the rotor even when your foot is nowhere near the brake pedal?
That was my problem, always rubbing, now after rebuilt calipers, no issue with pads constantly rubbing on the rotors. Like you said stops the pads from constantly touching the discs when in motion.
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
