Hey
I am putting a new turbo setup onto my RB20 but just had a quick question in regards to vac lines for external wategates
Where do the vac lines from the top and side of the wastegate go?
Also if I want to hook up a bleed valve how do I go about doing that?
https://www.sau.com.au/forums/topic/209018-external-wastegate-lines/
If you are using just a manual boost controller (ie bleed valve etc) or no boost controller you connect the vacuum / boost line to the base of the WG actuator. It opens the WG when positive pressure is applied...The top connection when pressurised acts to hold the WG shut so dont use this one...
Some or most electronic boost controller use both. They do this so that they can hold the WG closed for longer...
The top connection also acts as a breather so make sure you dont block it off other wise the WG wont work properly....
Now for the other question, where does that boost line come from as RB20 doesn't have a solenoid and the front of the turbo doesn't have an outlet for a vac line
Do I take it off the cooler piping somewhere, or can I hook it up off the intake manifold?
Ok I have to say I am slightly confused now
The yellow line I can't run to the comp cover because it doesn't have an outlet on the front of my turbo
The blue line to the cooler piping is there standard so I assume I don't have to worry about that?
The red line, where is that coming from is or is just a hose connected to nothing?
Would the bleed valve connect in-line with the yellow line?
Okay so the yellow line will be T pieced off the blue line
Now the red line is that coming off the intake manifold also? And how to I tap a bleed valve between the red and blue?
Sorry for questions, just want to get it right the first time!
Picture updated with my outstanding MS Paint skills
That diagram looks as if it is for an EBC set up???
I would not connect the top line because in your setup it should just be open or a breather...Take one line from your IC pipe work and connect it to the base of the WG actuator...make sure this works first and then worry about the bleed valve..
Do you know what size spring is in your wastegate?? It may be just give you the boost you want with the nedd for the bleed valve....also do you realise you can get different springs for external WGs...
ah ok now I have no idea what to do now lol
I am not too sure what spring it is, its an old school style HKS gate, but not interested in changing springs
I would rather just bleed it to what I need and leave it there
I need it to run like 19psi but for initial tune about 12psi
Anyways not relavent, I just need to know how to hook it up with a bleed valve then I will work out the rest once its on the dyno
Just remember that it is impossible to achieve boost below the psi of what the spring is...ie if someone has put a 19psi spring in you cannot achieve 12psi...some external gates come standard with pretty big springs...they are generally colour coded to nominate the psi of the spring...
Yep not a problem, thanks for that
I might pop it open and take a look, but doubt it would be anything to high
I just need to get the lines right pretty much then the tuner can play with the boost and set it to what he wants
I've always been a fan of trying to get the spring tension such that you acheive the right boost with just a little bit of bleed, as opposed to using a light spring and bleeding off heaps of air..Bleeding of heaps of air I dont think is the way to go because there are more variations that can occur...
ie bleed valve can move and will behave differently if moved to a different spot in the engine bay and runs at a heaps different temperature...
Also technically the bleed valve is a boost leak so you should always seek to minimise this...
You should consider a good EBC in the near future...
lol, sorry man, was just taking the piss outa taxi :D
As mentioned, turbo outlet to bottom half of WG. Top side leave free ( you can purchase little cork filters, to stop shite from getting in there)
You'd hook it up, the same way as all bleeders I would think. Check TurboSmarts nice little PDF
Doesnt matter u dont a T there... anywhere between turbs and throttle body will do.
Cheers
Edited by GeeTR
Lets just not worry about the type of boost controller for the moment
For now I just need to know how to hook the vac lines up properly to the external gate so I can run the bleed valve and control the boost properly
:D
For your purposes I would just treat the external WG as if it was an internal one but just make sure you use the bottom vacuum line connection...Leave the top one open and dont connect anything to it...You then just use the bleed valve as if you had an internal gate...This will work just the same.....The bleed valve wont know any difference...
    • Major thread necro but how bad of a job is it to DIY? Looking at it online it looks like if you reuse your ring and pinion as long as those are in good condition it should be fine to just pull the axles/front cover and replace the diff that way? Or should I be replacing everything and doing preload measurements/gear mesh testing like the factory service manual mentions for the rear diff?
    • in my list I had the R33 GTR as the best Skyline. Infact I had all GTR's (33>34=32), the NSX, the GTO, the 300ZX, the 180SX, the S15 better than the FD RX7. I had the MR2 and the A80 as 'just' better. I also think the DC5R Integra looks better but this is an 01 onwards car. I also think the FC>FD. It's almost like aesthetics are individual! The elements @GTSBoy likes about the FD and dislikes about the 180 are inverse in my eyes. I hate the rear end of the FD and it's weird tail lights that are bulbous and remind me of early hyundai excels. They are not striking, nor iconic, nor retro cool. The GTO has supercar proportions. I maintain these look much better in person (like the NSX) especially with nice wheels and suspension which is mandatory for all cars pretty much. Some (or all) of these you have to see in person to appreciate. You can't write a car off until you see one in the flesh IMO. Like most people we probably just like/dislike cars which represent certain eras of design or design styles in general. I also think the 60's Jag E type looks HORRIBLE, literally disgusting, and the 2000GT is nothing to write home about. FWIW I don't think the Dodge Viper Gen1's have aged very well either. You can probably see where I rate bubbly coupes like the FD. I know we're straying now but the C4 and C5 absolutely murder the Viper in the looks department as time goes on, for my eyes. Wouldn't surprise me if people who love the FD, also love the MX5, Dodge Viper, Jag E Type, etc etc.
    • I used to hate R31s, and any of the other Nissans that led up to it, and any of the Toyotas with similar styling, because of the boxiness. They were, and remain, childish, simplistic, and generally awful. I appreciate R31s a lot more now, but only the JDM 2 door. The ADM 4 door (and any other 4 door, even if they are unique compared to our local one) can eat a bowl of dicks. The Aussie R31 is also forever tarnished by their association with stereotypical bong clutching Aussie R31 owners of the 90s and early 2000s. I think the Nissans of the 70s (other than 120Y/180B/200B) are far superior looking to the 80s cars. The 240K era Skylines are boss. The same is broadly true of Toyotas. Hondas don't ever register in my thinking, from any era. Mitsus are all horrid shitboxen in any era, and so also don't register. Subarus are always awful, ditto. Daihatsus and Suzukis also don't generally register. They are all invisible. I think the SW20 MR2 looks fiddly. The 3000GT/GTO is like that but way worse. Too many silly plastic barnacles and fiddly gimmicks ruined what could have been a really nice base shape. Kinda-sorta looks like a big heavy ST165 Celica coupe (and I'm not sure if that's a good thing or a bad thing). I think the 180SX is dreadfully bland. It's not bad looking. But it has no excitement to it at all. It's just a liftback coupe thing with no interest in its lines, and bad graphical elements (ie wide expanses of taillight plastic on the rear garnish). The S13 Silvia is a little better - getting closer to R32 shapes. But still....bland. S14? Nope. Don't love it. S15...a little better. Probably a lot better, actually. Benefits from not being like a shrunk in the wash R34 (where the S13 was a shrunk in the wash R32 and the S14 looked like a Pulsar or something else from the stable on Nissan mid 90s horrors). The Z32 was hot as f**k when it came out but hasn't aged as well as the A80. Keep in mind that I think the R33 is the most disgusting looking thing - and out of all the previous cars mentioned is objectively closest to my precious R32. It's just....real bad, almost everywhere you look. And that is down to the majority of what was designed in the 90s being shit. All Nissans from that era look like shit. Most other brands ditto. In that context, the FD absolutely stands out as being by far the best looking car, for reasons already discussed. Going behind the aesthetics, the suspension alone makes it better than almost any other car.
    • If they just called it the "Mazda Tiffany", it would have been spot on.
    • Yup but for me its the HR ! Cut my teeth on the old holden 6s in the day ! And here's me thinking in the day it was also the 300ZX and the Mitsubishi GT3000 ! All, as well had good lines, but always seemed to need finishing off, style wise.
