hey!
I have a bit of a hypothetical question for a few cluey engine gurus
i am planning a trip to look at a a car (r32gtr) over 3000 kms away.
Now after pumping this guy for as much info on the phone as i can this is what i have managed to get out of the convo
the car has some sought of vapor coming out of it on down changes which the owner says he has been told the cat is buggered after he took it into get a new cannon put on it and that its whats causing it to blow smoke etc on a down change
he tells me that he reset the PFC back to base map because the engine was detonating after the exhaust mod which i would assume the car is running rough/Rich...
does a worn out cat (original or 14 year old Approx) make exhaust vapor/Dust on a down change or is there something maybe wrong elsewhere in the engine ?
the strange thing is that he only reset the pfc after the exhaust change so i am thinking its not fuel coming out of the exhaust as the exhaust place was the one that told him his cat was buggered and this maybe the cause of the mysterious gas/dust/fuel/oil comong from the exhaust pipe...
Could someone help me out on what maybe going on with this...
he is fairly sure its not blue smoke but in saying that he dosent understand engines to well either
thanks Dj
Edited by ish
Those vapours could be from an ATMO or hybrid BOV on a down change. At high rpm a blocked cat can cause a leak b/n flanges
Sounds ok, increase in breathing hence running richer thus noticably more smoke. Without a tune it would run rough, if not stall with the ATMO unless compensated for with the PFC. Not sure about the detonation, maybe it has something to do with the missing air that the atmo releases and the sys. cant meter
LOTS AND LOTS OF SMOKE. FILLS UP THE CABIN, CANT BREATH, PINK SMOKE BLUE SMOKE YELLO SMOKE AND SMOKE SMOKE.. :-P
Pretty sure All skylines pump a bit of smoke out if they have not been drivin in a long period of time.. gotta remember its a 18 year old car..
CHEEEEEEEEEEEEEEEEEEEEERS
could be the pcv valve sucking excessive blowby in when the car decelerates and engine inlet manifold vacuum is high. pcv valve is closed under boost.
otherwise if the car is cold and has atmo bov, could be dumping fuel in on decel because of the unmetered air exiting the bov, when its hot it should fuel cut altogether (turn off injectors) on decel so you shouldn't get fuel smoke from atmo bov.
    • It's excellent but I'm still breaking it in so I'm not 100% sure where it'll end up. I would say it's about 15% heavier than stock and the smoothness of the slip zone is quite progressive but you need to be a little patient compared to stock or it'll bite hard and stall. Stock I got away with absolutely horrid clutch control. Like I said before I couldn't even tell where the clutch would grab when it was stock so releasing way too quickly without enough revs it would just slip and the revs would drop lower than ideal but that would be the end of it. Currently there's a bit of a nasty clutch judder if I don't apply enough revs + find the exact wrong point of the slip point in the clutch pedal but it feels like it's slowly resolving as I drive it more. I would not recommend the competition clutch unless you really need the extra clamp force. I think this clutch combined with the Nismo operating cylinder is going to be exactly what I want. Enough bite that you need to remember the release point to avoid stalling or rough shifts, but progressive enough that it's not hard to drive by any means and not heavy at all. I tried a "super single" clutch on my friend's 997.2 Turbo 6MT and that was absolutely horrid. It runs an electrohydraulic power steering pump for the clutch power boost so there's zero feedback in the clutch pedal and there was a horrific clutch shudder well after break-in due to the lack of marcel springs or hub springs in the friction disk. It felt like the slip zone was the thickness of a single toe twitch as well so it was almost impossible to avoid stalling it unless you gave it a ton of revs and just dumped the clutch instead of trying to be smooth with it. I was terrified of pulling out in front of traffic. I have also tried some kind of "super single" on an EK9 and that makes this twin plate Coppermix look like a stock clutch. Releasing the clutch pedal even slightly too quickly feels like you're getting rear-ended. The pedal is extremely heavy as well and there's no vacuum assist like the GTR.
    • Yeah, well I was probably way underguessing the $300 figure anyway. Just multiplied a "normal" by 4 for the purposes of pointing out it's not cheap, particularly if it has to be repeated.
    • We have an alignment shop out here that does what you're talking about but he wants like 800 AUD a pop. DIY is "cheaper" but once you start accounting for the value of your time I'm not sure it's worth it.
    • The main catch phrase for any car is "the eye of the beholder", and "personal tastes and preferences" And as for the plastic "flares", I honestly think they look cheap and tacky, and I cannot see them aging well, maybe if they were body colour they might look better to my eyes, but, I would still prefer it the were more like the older WRX STI models that had the wider body metal panels In saying all this 5hit, I wouldn't buy a new WRX again, even if it had the wide body metal panels
