Hey all,
The next event on the Vicdrift calender was ment to be a comp but due to our calender being all stuffed up from calder priceing pushing the venue out of our calender.
March 16th at winton raceway is probably going to be run as a normal vicdrift practice style day with the comp held in the afternoon.
who's coming?
The first drift event at winton this year and its set to go off!
I shall have solid details about the event tomorrow night and i'll post any updates in here.
If you have any questions feel free to PM us or just ask in this thread and we'll get back to you asap.
www.vicdrift.com
Cheers
Joel Collie
VicDrift- Marketting Director
https://www.sau.com.au/forums/topic/209060-vicdrift-practice-day/
K people I've got the official word, we all went round for C-Spec bolg and meeting. We have decided that this next event, the 16/03/2008 will be run as a practice day.
Changes have also been made to the general running of each event this year. Practice/comp days will be run, the idea being that each event noted will be practice in the morning, qualifying in the afternoon for street & Pro classes and then points based comps in the afternoon. the top 16 will be seeded and placed in order of rank to go head to head in this year's Drift Attack!
look to the website. www.vicdrift.com for updates, and don't forget to sign up to our forum to stay current, and have a say with vicdrift
Thanks,
Joel Collie
Yep it is the same pricing as years previous
Edited by sambbb
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
