Ive got a '92 R32 gts4, and i crashed it!
So now i need parts and info.
Ive been told i need Godzilla parts, and that GTR bits wont fit?
I thought they were the same thing, but my crash repairer says otherwise.
Does anyone know of any parts (front end stuff), or a cheap complete car? I dont need a motor, just chassis and suspension bits.
Any info would be greatly appreciated, anything you could tell me would be of great help
https://www.sau.com.au/forums/topic/209073-r32-gts-4/
Most GTR bits will most definitely fit. I have an R32 GTS4 too.
You'll find the rad support, guards and front bar are different, as is the engine (obviously) and supporting bits... but the hubs, suspension, rails, rad support etc are shared.
https://www.sau.com.au/forums/topic/209073-r32-gts-4/#findComment-3696710
i'm gonna say that its a write-off. the chassis is certainly bent and you would be better off getting a new one and stripping all the good parts off this one and selling them to recoupe some of the losses.
Hey Shan, reply to my PM! :D
https://www.sau.com.au/forums/topic/209073-r32-gts-4/#findComment-3696725
PM? oh... oh yeah... replied :D
Yeah it does look like a write off, although if you were to replace the front section of the rail, the inner guard and the rail it might be ok... big job though. I'd say your insurance company would just write it off.
https://www.sau.com.au/forums/topic/209073-r32-gts-4/#findComment-3696758
yeah, i reckon any insurance company would write it off - but even from a economical point of view, it looks like it would cost close enough to the value of the car to repair (i'm talking about a proper job - no shortcuts!)
https://www.sau.com.au/forums/topic/209073-r32-gts-4/#findComment-3696806
    • It's more like on average the things I see a lot of things going wrong. Yes, usually the people who reach out are the ones who are having problems but on average it feels like mechanics and tuners here aren't really competent. I swing between thinking my standards are just way too high and wondering whether people really are just this dumb. I just had the strangest 10+ reply argument on a Facebook group over someone insisting that the factory R34 GTT boost control solenoid reduces boost pressure to 5 psi when it's on and raises boost pressure to 7 psi when it's off despite showing the exact plumbing in the factory service manual and the solenoid behavior detailed in the FSM.
    • I steam cleaned my near new set of volk gtc wheels 14 years ago and farrkkked them lol. The clear coat cracked like spider webbing in several areas. Lesson learnt don't do that. ๐Ÿ˜ญ
    • If you don't touch the CAS, then you're fine.
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
    • I hear the old "I'd never use a pressure washer on my motorbike" BS in the dirtbike community too.ย  The only people that have had a problem from using a pressure washer on anything are the people that aren't using them properly.ย  If you hold the wand any more than 45 cms away from pretty muchย anything (radiators, wiring connectors, paint, etc) you aren't going to cause any damage.ย  We've had detailers wreck moulds and seals on cars at work before and the only reason why is they held the pressure washer too close and on the one spot for too long.ย  If you have 5% more brain power than a detailer then you know not to not do that and you'll never have a problem.
ร—
ร—
