Make: Nissan
Model: 1996 R33 GTS-T
Milage: 79,000kms
Transmission: manual
Colour: blue
Complied? yes
RWC supplied? yes
Currently registered? 12 months rego
Price: $17900 firm
Contact: william 0416416496 after 530pm
Comments / Modifications:
5 speed manual
fibreglass vented wide front guards
aftermarket bodykit
KKR 430 turbo (500hp) with braided lines
custom high mount manifold (short runners)
custom polished jun stlye inlet plenum
Forged Pistons , rods
Ported & Polished head
Metal Head gasket
Oringed block
ARP headstuds & mainstuds
trust 50mm external wastegate with screamer pipe
bosch 040 in tank fuel pump
custom power steering setup
twin breather air filters on rocker covers
Chrome oil cap
remapped ECU
Grounding kit
Master Cylinder stabiliser kit
strengthened tailshaft
exedy heavy duty clutch
lightened flywheel
3" custom turbo back exhaust
k&n pod filter
Gates Racing Timing Belt
76mm thick intercooler with custom piping
polished rocker covers
front polished strut brace
hks turbo timer
Clear side indicators
18" lightweight wheels (new tyres)
autometer boost gauge
autometer air/fuel gauge
Tinted Windows
Air conditioning
Alarm with remote central locking
sony headunit
sony 6" speakers
12 months rego
very quick car made 260rwkw with old motor before rebuild and with smaller turbo. Should run close to 300rwkw now. Engine has just been built and run in. Is like brand new
Contact Details: call William 0416416496 after 5.30
Images:
https://www.sau.com.au/forums/topic/209100-96-r33-gtst-series-ii/
    • OK, solid mount Z1 diff brace is in, pretty straightforward, it picks up 3 diff hat bolts and ties them to 2 support bolts on the subframe. Pretty sure someone else on here said they had reduced axle tramp with this but mine was already pretty good for smooth wheelspin, and still is....will see you this goes over time and whether I end up with a broken rear diff hat
    • Ah yes, but the part in my hand was actually painted and fitted by me! I knew any front lip was likely to be sacrificial but I've had to fix it twice already... by the time I buy a fibreglass fixing kit, sort out sandpaper blocks, buy some fibreglass filler, body bog, spend the time and effort for a 'Greg' result... a new one being $290 seems like it's the better way to go and spray that with bedliner/raptor coat and we're all pretty again.. Would have preferred it last more than a month though. Them's the breaks I suppose.
    • I find it funny that the USA is finding out all this really really weird stuff, and people from the USA are coming here treating it like gospel, yet, all the info on solving those issues is here on these forums for the last 15 odd years... Also, I know how much heat it takes to ignite the hood lining of an R33 skyline. I worked it out myself... It also took a LOT of time, and heat for it to do it... Big single, and I needed to drive the car, so retarded the timing off to "protect it". Yeah, that was a bad move for cruising on a freeway with only 15 degrees of timing on it. That was a lesson I learned around 2009. So that's over 15 odd years ago. Aligning water and oil, that's identical for any turbo engine, it's not Japanese specific. If a shop doesn't know how to make sure the core is rotated the right way, then they shouldn't be touching any turbo engine. That's not a matter of "We haven't had Skylines for that long here"...
    • Sounds like it is rotational in the driveline. CV? Tailshaft CB? Also.....didn't you just pay to have that bit painted and put on the car?
    • Yeah, when I dialled my idle down, given how much time I spent idling at the lights in traffic on my daily commute, the effect on overall fuel consumption was absolutely noticeable.
