After the big end bearing let go on my 1989 R32 GTR on May 12 2007 on the SAU 'haunted' cruise I can finally collect my car tomorrow.
This has been a long and drawn out saga that has cost ridiculous amounts of money. The short version for those who don't know:
  • Did my first ever 7000rpm launch in the car and spun the big end bearing on a Friday night SAU cruise back in May last year.
  • Within a week the car is at Willall Racing in the capable hands of Peter Hall.
  • Peter and I discuss the rebuild, decide which mods I'll get and he gives me a quote.
  • The work begins and the engine is stripped while I source parts from Japan.
  • Unexpectedly and with no explanation given (to me) Peter Hall leaves Willall and I'm left with an engine in pieces.
  • I approach Steve Cramp from Manta Racing to complete the rebuild but don't obtain a quote.
  • Steve struggles to find all the pieces of the engine and 4 trips are made to Willall to look for stuff sometimes spending hours looking for bits and pieces.
  • The $ have more than doubled my original quote.
  • Finally by October the car is back at Willall for Martin Donnan to tune after I have completed 500+km breaking in the new engine.
  • The brand new PFC fails and on Martin's and Steve's advice I send it back to Nengun for repair under warranty.
  • 3 months later Nengun inform me that there was nothing wrong with the PFC and I have to pay to get it sent back. Add other $235 and another month to the total.
  • Finally I get the PFC back 2 weeks ago and leave the car and the remaining mods with Steve last week while I go to Fiji for a mate's wedding.
  • I get back today and read an email that Manta wants another $1230 but the car is ready to be collected although now the HKS EVC boost controller no longer holds constant boost so they have re-plumbed the system and have it running at 17psi. I have never had any problems with the HKS EVC before.
Can you guess what it made on the dyno? (I haven't seen the sheet yet but know the figure)
Mods:
HKS GT-SS turbos at 17psi
HKS dumps
CP forged pistons & rings
Tomei forged conrod bolts
Apexi FMIC
Apexi front pipes
Turbo back 3" exhaust with 3.5" high flow cat and 4" tip
Tomei type b poncams 260 IN/EX 9.15 lift
Tomei adjustable pulley set
R33 GTR long nosed crank
SARD 700cc injectors
Nismo AFMs
Nismo timing belt
Nismo fuel pump
Splitfire ignition coils
Tomei 1.2mm metal head gasket
Tomei 1.5mm oil restricter
N1 oil pump
Tomei sump baffle kit
GReddy oil cooler
GREX oil filter relocation kit
Apexi PFC
plus lots others to suspension, interior, exterior, brakes etc.
Edited by writeoff
https://www.sau.com.au/forums/topic/209102-finally-my-car-is-ready/
You probably already know that Pete Hall went to Outlaw's
Dave, any chance you could get the Nismo AFM values that Martin put into the PFC and maybe the Sard 700 injector correction and latency figures?
Similar setup to mine so I'm guessing approx 330 - 340kw.
[*]Did my first ever 7000rpm launch in the car and spun the big end bearing on a Friday night SAU cruise back in May last year.
wasn't it against a 34 GTR? :ninja:
sorry, how much was the total bill?
GT-SS with supporting mods @ 1.2bar
it should be around 315-330rwkw
Edited by andz
I'll post the dyno sheet tomorrow after I've seen it.
Total bill was WAY the f**k too much.
I can't wait to drive it although a double demerit long weekend is not ideal. When are we going to have a new race track & drag strip?
Hooray!!
All I can say is "bout bloody time" considering I bought writeoff's other GTR around the same time... cant believe its taken so long
Well. it'll be good when u can go on a cruise, then it'll be worthwhile :)
-D
Yeah its an expensive process been through the same thing myself lately mate but in the end after you drive it you will appreciate it more knowing how much time and money its taken to do. GL with it and enjoy it nice setup.
Why do you need a new race track? Mallala is there, go take it on a practice day..lots of fun, especially with all those goodies.
Mods:
HKS dumps
Apexi FMIC
Apexi front pipes
Nismo AFMs
Nismo timing belt
Nismo fuel pump
N1 oil pump
GReddy oil cooler
Apexi PFC
im guessing parts and labour around the $16k mark?
and power around the 350kw mark.
    • I had absolutely no symptoms whatsoever that anything was wrong.... I'm very happy it was all spotto'd and re-bled and re-torqued and aligned though. Will be picking it up tomorrow and undoubtedly be like "Oh, that clunk is gone" "Oh, the car really wants to drive straight" "Oh, that pedal feels better" "Oh, it feels like I've gained 25hp" "Oh, the handbrake works now" It should have been a sign that the new Project Mu shoes had 3mm of pad depth on them out of the box, and the OEM ones from 25 years ago that we took out also had 3mm of pad depth, implying the issue was not, and never was the shoes, but we put that down to it not being adjusted correctly. It wasn't, but it wasn't even adjustable at all given one side was boned and the T Junction of the cables was on a 45 degree angle, the non-working side being the one on the massive angle. Obviously when I had adjusted it and reset it and re-tensioned it I had either got it stuck or something along those lines. Oh well. Live and learn and absolutely could have been catastrophically worse so I'm rationalizing it as a win, kinda. I also got the chance to measure the distance between rear rim and the suspension arm/shocks and found a 30mm rubber block only just doesn't fit there. Which is great to know before ordering wheels, when I assumed 30mm was easy. The man with the Porsche adapters has rims that use 23.9mm of that space, so it's safe to assume I have between 23.9 and 29.9mm of space there to play with on the inside. The wheels looked pretty stupidly pokey with the 20mm spacers on the rear, only for me to find that the studs come out another 12mm and the wheel doesn't actually sit flush with the hub because you're supposed to cut your original studs. The wheels do have cutouts that kinda accomodate it, but not fully. So my 20mm spacer was anywhere between 25mm and 35mm. ~25mm and send it will determine on where the wheels sit with the spacers on. When I put the pads in for the track day I will mess around with spacers (with wheels that do not clear studs properly when mounted to spacers) and do more math, for the last time, for the 7th time.
    • Lucky pick up Best to find these things before something horrible happened to the yoke flange thingies I would hate to think what would happen if it dropped the tailshaft  Hopefully the holes are not flogged out in the yokes and it was just the bolts that got munted  As for the hand brake.....ouch, look like the disc got rather hot, and I assume smokey, I recall when I had a front caliper seize on the Commodore, there was lots of smoke and the disc was glowing cherry red when I was able to eventually stop and have a look, and stopping a big heavy car, going down a big hill with some rather high RPM down shifts and some hand brake action is something that makes you think hard about life
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that one side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
