Hey Guys,
I just bough a 92 r32 gts-t, its stock as a rock. The car drives well, boost kicks in at 3000rpm and is full of power till 5000rpm where you feel like a lack of power from there till redline.
I was wondering has anyone had the same problems, if so what should i be looking at.
Thanks for your help
https://www.sau.com.au/forums/topic/20914-r32-gts-t-loss-of-power-5000rpm/
a BOV?
how would that make it any better?
they come with one from the factory.
Anyhow... the turbo on the RB20/s... red/silver tops runs out of puff around that mark.
If your car is stock as you say, then get your exhaust done, that's a good start.
That'll give you more all round, and the boost will naturally rise a 1-2 psi with that also
it gave me a little better bottom end too on my old coupe when i had it done.
you'd be surprised at the difference and the responsiveness.
If that's not enough do what others do and put the RB25 turbo on your car. and give it a bit more boost to boot...
it'll pull all the way to redline then!
I had the same problem and it turned out to be that the knock sensors were disconnected. at around 5300-5500rpm there was a noticable drop in power, drove me insane. Search the froums on how to do a diagnostics with the ecu and that will tell you. Good luck. Also now with the knock sensors connected it made ok power to around 62-6500rpm.
Nah, im saying when I bought the car the owner had the std. bov fitted due to being defected. The car felt really restricted above 5k. I fitted the hks sequential that the owner gave me, reset the comp, the "viola", dont ask me why, it revved so smooth to 6500 -7000 rpm.
Im not saying this is a solution, or starting an argument, I'm saying this is what happened on MY car.
    • Went looking at mine, reading off the tyre, presumably these are 1st week of 2003. Still hold air (I haven't had to pump them up in over 12 months!)     I couldn't quickly find the date on the front tyres, they were fitted around 2008 to the rims, so probably not quite as old, but they have a lot more dry rot cracks in them. Still hold air.
    • I am now intrigued to go check the dates on the tyres on my Skyline... We need a game of who has the oldest tyre still holding a car up, and successfully holding air (for longer than a 2 weeks I feel is successful air holding).   I feel your tyres may be beating mine
    • Ok, still waiting for a date to get the cams installed on the MX5, why so long, because MX5 Mania has received a few new sets of different cams with different specs for the MZR and are currently trialling them, and working out what is best for 2.5 "powers" with stock internals, in the end if I go bigger than the Kelford stage 1 cams I'll need to look at the valve springs  Hopefully I'll get the news on them next week As for the boot of the car getting fixed, I hopefully pick it up early next week, I was sweating on picking it up yesterday but, meh, it was not to be, so ne weekend cruising for me
    • Ok got some old tyres for you guys...my car has been sitting around un-driven for about 6 years now. I had it on the original rims with the shitty compliance tyres it got it with back in 2006, which were manufactured in 2004... Sidewalls eventually rotted and split open, obviously no air in them and the rims were holding the car up. Just swapped them with some 17" Work rims and tyres which are probably 10+ years old too but at least holding air
    • Nah mate, safe as $800k apartments
