anyway ive grabbed a set of these
the price made me smile so if you want some here are the details
this is to upgrade your r33 gts or r32 gts or r32 gtr
for your 715 dollars
you get
DBA 4000 seieries rotors 324mm
use your existing stock calliper for R33 GTS-T and R32 GTR
you also get the billet adaptor brakets with all bolts and nuts and washes and love
$715 +delivery or pick up form seven hills
this makes a huge diffrence if you hit the track alot
especially on r compunt tyres
if you want to go hard core
add 400 and you get dba 5000 series rotors
anyway this isnt a group buy this is just he price that i can get
there is a pocessing fee of one six pack include in the price otherwise go pay retail of 800
lol
cheers
fatz
bank details
peter carruthers
bsb 112-879
4acc number 28 965 807
in stock at the shop ready to runmble
Um, Fatz are the brackets & bolts (dolts?) available seperately?
lol
sadly sau doesnt like my web browser so i can go back and modify my post
but yea the bolt and bracks can be bought seperate
illf ind out the price
  • 1 month later...
Just a question,
would you be able to get me a set of slotted street rotors to suit an r34 GTt I think the fronts are slightly larger compared to a 32/3?
My rotors at the moment are paper thin and can no longer be machined.
PM me if you like,
much appreciated if you can help, I live 15 minutes from Blacktown too so pickup is no problemo, can pay cash too
p.s what type of beer do u like :down:
  • 5 months later...
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
