New Fuel Pump And More
335
 Share
Hello
I am getting a new fuel pump soon to replace my old one. I have everything stock in the car except for a catback exhaust and pod. If I get a bigger flowing fuel pump do I need to change the injectors or get the car tuned?
Thanks
Help
A new pump won't need new injectors or tune. You only do those if you're upping boost or doing other mods.
Just make sure the pump (depending which) gets some decent voltage (above 12v to my understanding) and it'll run all day.
Tune will be the next step. Injectors if you change turbos.
Edited by R338OY
^yup
Fuel pump and flow is like Girl Scouts knocking on your front door trying to hock cheap cookies.
The number of em can increase, but it wont effect your wallet... as long as you don't open the door (injectors) lol
 Share
    • Oooohhh man did not bloody know that, that's amazing thanks heaps for sharing mate, bookmarked it!
    • In case you haven't come across it, there's also https://nissan.epc-data.com/ Go by VIN or drill down into your specific model and year and it'll have references for pretty much all the OEM parts. In very similar diagrams. Linked against amayama as well for ordering. Though they can be a bit slow and can be better to search around to get the parts locally.
    • Just in case anyone finds this in the future, here's a diagram sent to me by Nissan to identify these hoses. I ended up finding them through EFI Solutions though because Nissan reckons they need to order it from Japan, with a total cost of approx $110 inc. So it as cheaper with EFI anyway. https://www.efisolutions.com.au/blow-by-hose-rb25det-r33-wc34-c34-c35 https://www.efisolutions.com.au/blow-by-rocker-cover-hose-rb25-r33-wc34-c34-c35
    • This is an older post of mine but I just thought I should update it and explain what the problem was. Long story short the friction plates were below their service limit. New they are around 4mm, and service limit is (according to OSG) 3.5mm In addition the crank seal gasket wasn't sealing 100% anymore and that led to an oily clutch. Not sure what came first and why the clutch was worn after just 10,000km .. but all good now. OSG refresh kit via Nengun
    • My r34 GTT auto transmission is slowly letting go, slipping every now and again, tiptronic deciding to not keep it in 1st / 2nd when flooring it, taking longer to shift so I’m going going flush it and replace the filter and hope it lasts a bit longer.    I’ve got 10L of Penrite ATF FS at home and I’m going to use it for it unless ye completely recommend against it.  Penrite list it as compatible. i understand I should be using Castro Transzmax however it’s quite expensive and I already have 10L of the ATF fs. Has anyone here used atf fs for there got or heard of anyone? Or am I silly for even considering anything other then Castrol  Thanks for your advice
