Hey guys,
I own a 93 r32 gts-t, mods are displayed as you can see.
(Plugs are roughly 1000kmz old and i cleaned my standard coil packs with contact cleaner not long ago)
I experienced some sort of speed or fuel cut while driving in 3rd gear (flat foot.) Its only happened twice
and both times have been roughly around the 115km/h mark. All of a sudden it stops reving even though my
foot is still down. But once i take it off and put it back down again everything seems to be fine.
My Ecu is remapped and im running 1 bar of boost.
Has anyone experienced this or know of?
Cheers Adrian.
https://www.sau.com.au/forums/topic/209217-speed-cut/
Could be anything mate.
Coils could be going
Fuel reg on the way out and stuffed plugs
Fuel pump moving around
Crank sensor or ignitor pack showing age
Its trial and error with a 15+yr old motor.
Either way you cant do 115km/h legally anywhere - so behave!
https://www.sau.com.au/forums/topic/209217-speed-cut/#findComment-3699858
We can do it here, on the highway, speed limit is like 100km/h but no one drives that slow. Seen subaru's doing well over 270km and i personally drive like a maniac at 220km max (have to find out what's stopping my speed lol) on the highway and over 100km on normal street. Everyone here does it so it's farely common. Even my mom drives over 140km in her corolla 1.6 sedan lol.
It is illegal but the police doesn't seem to bother that much on the highway.
Attached is my '94 Sunny 1.5cc Carb GA15DS Engine doing 190km.
Attached '96 R33 GTS25t doing 220km
Edited by teng
https://www.sau.com.au/forums/topic/209217-speed-cut/#findComment-3702277
We can do it here, on the highway, speed limit is like 100km/h but no one rives that slow. Seen subaru's doing well over 270km and i personally drive like a maniac at 220km max (have to find out what's stopping my speed lol) on the highway and over 100km on normal street. Everyone here does it so it's farely common. Even my mom drives over 140km in her corolla 1.6 sedan lol.
I'll try telling the local police in Australia that next time they pull me over.
OP wats the condition of ur AFM like?
https://www.sau.com.au/forums/topic/209217-speed-cut/#findComment-3702293
i tried to run my bros car off the clock the other day (private road) and was suprised when it hit a massive cut at 180clicks but was only at 5500rpm in fourth gear.
so it can't be rev limit, has no speed limit set or speed signal even hooked up for that matter and has rich and retard limit removed and air flow meter that is no where near peaking out.
my verdict is it must have been the standard rubber inlet sucking close, all i can think off for such a massive cut off.
if you have standard ecu but, could be anything to do with that.
https://www.sau.com.au/forums/topic/209217-speed-cut/#findComment-3702556
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
