I know heaps of ppl say china manifolds crack n shit, but alot of people say they are fine.
From what i have gathered, a majority of those with china manifolds that have cracked were wraped in heat wrap...
ii currently have hks2535 turbo with gktech dump/front but im suffering from a bit of lag and spiking problems (due to running boost on actuator).
anywho i decided its time to go pfc + gate but i was just wondering if i should just keep the standard manifold - which i heard its very hard to weld a gate on it
or
take the risk and get a china manifold.
if both options are crappy how much for a very decent china manifold or a jap one?
thankyou kindly
https://www.sau.com.au/forums/topic/209238-external-gate-on-stock-manifold/
im running a china manifold, modified tho, making 800hp. no cracks as yet, was a tad hard to fit as the stud holes werent perfectly aligned... had to weld a t5 flange on it for the gt45 to fit.
to weld a stock cast manifold is not at all hard, what IS HARD is welding it with a crappy welder. if youv got the good gear youl get good results.
my2.5 cents lol
catcha
dan.
thanks dan
and yeah also i heard that some china manifolds have metal shavings IN the pipes which have to be cleaned up before they are fitted otherwise heat + metal shavings = going into ur turbo :S
which brand china manifold did u go for?
well actually i still have the stock dump + front i have yet to install the gk tech stuff... i just wanted to paint a picture as to what will be on the car when it comes time to the gate...
ah icic
So will you be keeping with the 2535?
A proper dump setup will do WONDERS for the setup you have, im surprised its ridiculously bad with a restrictive dump like the good ole RB20 one :domokun:
I have had a chinese low mount manifold crack...Then I had a custom fab lowmount steel manifold crack..I drew the conclusion that any low mount pipe manifold for the RB25 is likely to crack...
Reasons why:
The RB25 lowmount manifold is long and thin. The pipes run along the manifold and of course expand with heat. The flange also gets hot but not nearly as hot as the pipes...therefore pipes will try and expand a lot more than flange..they run in same axis as the flange so they develop a shit load of stress because that have nowhere to go...high stress in steel means crack...especially if is goes through hundreds of cold hot cold cycles...
Any high mount manifold is a completely different story...The pipes run out from the flange...When they get longer due to thermal expansion they are not constrained by the flange nearly as much...so not nearly as much stress and less chance of cracking...
hope this makes sense
Ok, so forget welding onto the stock manifold or a china one, the factory one has a good heatshield and you wont get hassled over it too.
What about making a turbo spacer big enough to fit a small external to it... ? Positioned correctly you could hang it underneath and blend it back into exhaust with a small flex pipe and flange.. ? I think it was Japanese Motorsport, or whoever HPI were in cohoots with at the time who did this with an rb20 or something ?!
Or its also possible to weld onto the turbine housing... just make sure you get a specialist to do it. .... I am going to go the extension if i continue to have probs with the new larger hiflow as it already had a 10mm spacer to get comp cover to clear manifold ... also just need to extend turbine heat shield cover outwards also.
You could weld onto the factory manifold with success but you would need to get it done by someone who knows what they are doing...They need to bring the manifold up to a certain temp in a kiln and cool it properly after welding...you average exhaust workshop would have no idea..if they knew their stuff they wouldn't attempt...you need a workshop who is pressure welding certified. If it is done properly though risk cracking is very low...
Dont waste your money with an ex gate or aftermarket manifold on the setup you are running, its just not worth it. Your turbo has been shown to produce exceptionally solid results in low mount internal gate, thats how HKS designed it. So basically check your other options first.
Firstly as nismoid said get rid of your stock dump pipe, a nice bellmouth 3" should do the job well. Dont muck around with a split dump/front pipe, boost controll issues seem to occur (sometimes) with this design. The design listed below is good, shop around on price though.
http://www.justjap.com/parts_ndumps.htm
(X-Force Dump & Engine Pipe - RB20 / RB25, Price: $330, 3 inch Stainless Steel - Suit Skyline R32/R33 GTS-T)
Secondly get some forn of boost control. Try the $22 turbotech manual one, cheap, proven, just do it.
Finally if that still does not fix your problems check the health of your actuator, borrow one or buy one from a wrecker. This could also be causing your problems, not opening or closing properly could be causing the lag and the spike.
Good luck
my mate has a rb20det with a std manifold. He has a huge fck off hks turbo and between the turbo n manifold flange is a external gate adaptor... ill try get pics.. Basically its all bolts on!
ah icic
A proper dump setup will do WONDERS for the setup you have, im surprised its ridiculously bad with a restrictive dump like the good ole RB20 one :P
yep im keeping the 2535 for now only done 7500km on it..
i guess before i do anything about this gate thing i should just slap on the dump/front pipe n see what happens..
Good luck
and then ill put on this turbotech boost tap...
and check my actuator
if i still got problems time for gate lol. the sound will compensate for lag/overboosting :thumbsup:
but nah ill do them 3 things first i guess before considering gate..
dont get me wrong, the lag isnt THAT bad, but just feels like theres room for improvement..
when i say lag i dont mean megga lag, im talking it starts boosting at 3100 n hits full at 4 to 4.5k
I've found that, on my RB20, if I unplug the boost controller and run wastegate boost, the turbo is incredibly unresponsive. It takes just as long, if not longer, to hit 13 psi as it does to hit 16 psi with the boost controller on.
I never knew a good electronic boost controller would make lag so much more managable. Maybe try that instead of a bleeder valve? I ran one of those on the stock turbo and it didnt do anything but make lag worse.
Good luck
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
