Hey guys,
I would like to know if it worth changing the oil pump from standard to aftermarket (JUN etc)?
I just bought a R32 in Japan and as a first time GTR32 owner I do not want to blow the engine due to oil stravation....
Any help would be greatly appreciated....
Cheers,
thuy
https://www.sau.com.au/forums/topic/209270-should-i-change-oil-pump-on-gtr32/
Its a big job to do for just the oil pump.
Here's some things to do instead
-Always start the car and drive straight away(no sitting idle)
-Never use more than 25% throttle until the oil temp guage has moved above 70degrees
-Always use slow shifts until the oil has warmed up
-Dont use cheap shitty oil
-Always allow for cooldown time
Easy :laugh:
If you plan on taking it on the track, overfill the sump to the bottom of the hump on the dipstick, and try not to use r compound tyres (they generate lots of grip which moves the oil in the sump)
If you blow the motor up for whatever reason, THEN you do the jun oil pump :down:
wow thanks for the great tip
couple of question though?
-how do i know when is 25% throttle?
-does it help if i get a greddy oil sump?
and i think since you know so much about the car I also would like to know the following
- i just bought a Greddy T517z(2) would this fit on the hks dump?
-with the following mods
turbo back exhaust
oil cooler
pfc
is it ok for me to make 250kw@the wheels using standard injectors/pump? and not blow the engine? It will be tune by ben at Racepace
thanks for the helpmate
mate i would suggest putting a bigger oil pump for sure.
If by "bigger" you mean "higher flow" then you will increase the risk of oil starvation, as the higher flow pump will push more oil to the top of the motor than the standard pump. This will empty the sump more quickly, unless you add other oil control mods.
Read SK's oil control thread Here
+1 for N1GTRs tips, re 25% throttle, I think he just means take it easy until its warmed up, ie just drive at normal traffic speed. Also;
- dont hit the rev limiter
- dont use oil that's too thick. IMO ?W-40 is as high as you need to go with a quality oil.
- providing the injectors and pump are in good condition they'll be fine for 250
Only reaspn for pump failure is the gearset cracks in the pump, nothing to do with lack of flow. As previously mentioned more flow is actually worse as the problem is oil control in the RB's. With too much oil being delivered to the head and under high G-forces it just adds to the problem of oil starvation. Check the oil control thread if your serious about building a tough RB. Otherwise leave those bits stock. Its kinda all or nothing in some ways.
I read the oil control thread but don't really understand it. :thumbsup:
As I said I'm not going to even rev over 5500rpm nor take it to track/ hard corner etc....
Just want a reliable good looker car (i bought gtr32 after I sold the chaser manual) have I made a mistake?
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
    • Wives never seem to find things funny. Especially when they're trying to sleep, and you've found the new funniest thing ever. I've never seen someone be able to get try and be cranky with me, while they're holding back fits of laughter... 😛   Also, I tell mine it's payback anyway. She has BiPolar. So the household can get quite emotionally wild at times 😛
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
