would be silly to send shirts across then pay more postage to get them sent back to the owner. Why don't you just sell the decals to those that don't want white or XL shirts? And print out a 'how to iron on' instructions in the parcel??
Would be cheaper for all.
https://www.sau.com.au/forums/topic/209274-t-shirts/page/2/#findComment-3732963
when do you want to be doing this john? still good for the ones we spoke about via PM?
When do you want me to send the two shirts - and what type of material is best? like a close weave cotton or something i guess? Somethng without too much stretch so it doesnt wreck the transfer?
WOT, you haven't sent them yet? No wonder they haven't arrived..... I was waiting on the shirts.
Here is the easiest way...... I am going to print up the decals this week, and have some shirts ready for the AHG day.....
Those that have ordered specific shirts, they will be there, I'll PM you how much dosh you need to bring.
For Lil_booby... (oops) :P 100% cotton is best. The transfer will last about 3 years with "average" washing .... about 2-3 times a week. By that time, you probably A). Won't own a Stagea, B). Be sick of the shirt C). Put on weight and cant get into it anyway!! he he!!
I am also gonna print up the stickers .... nominations for each state rep please.
As Kylie :down: suggested I will put up a price for the Iron-on's only. But really they need a flat press. It is possible with a normal iron.
https://www.sau.com.au/forums/topic/209274-t-shirts/page/2/#findComment-3736235
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
