hi guys'n'gals
have an ongoing issue with my rear brakes. Discs and pads are 100% (been checked twice) but the rear pads are slightly 'glazed'. Apparently there isn't enough heat getting into them?? I think it means that for some reason they're not really clamping down on the disc or something like that (as you can tell, i know next to nothing about brakes)
just bought some Motul RBF600 today, got enough for a flush and refill, so that's the first step. But i was told it won't make a difference for my problem.
ABS seems ok, warning light hasn't ever come on, and when it was tested today, the guy got the ABS to work. And i know from a recent driver training day the ABS is definitely working. But an instructor also noticed that my rear brakes never really did anything, locked up i think he said (it was on a split surface exercise). But the ABS unit seems ok.
Took the car to arguably the most well known brake place in melbourne and their solution was to put some incredibly high performance pads on the car. Now, the pads recommended were absolute top shelf, no doubt, pricey but ultra impressive pads (endless cc-x) but i couldn't quite seem to get my point across that i didn't want to fix the problem with top quality pads, i wanted to diagnose the problem first and THEN take it from there. I don't want to just cover anything up with a great product which just hides the rear brake deficiencies so that they're almost non-existent. That seem crazy to anyone? I guess i just didn't quite explain myself properly.
Soooo wondering if i could pick up brains here. Besides a completely flush and refill with top brake fluid, what else can i check for what seems to be a dodgy rear brake bias where the rear pads aren't really getting any heat in them? Does that mean that they're just not really biting on the disc at all?
Problem is, i've started at the top in terms of brake workshops and haven't resolved the problem, and don't really know where to go from here :thumbsup: (with a track day on 15th march)
cheers,
daniel
https://www.sau.com.au/forums/topic/209292-rear-brakes-not-really-working/
If you are glazing rear pads because of insufficient heat then the answer is simple. You are probably running the wrong pad. For a rear you need something that works from cold. So for example a DS2500 as opposed to a DS3000 which needs some temperature. Some pads will glaze when used on a light duty for any length of time. Take them out & bash them with the bench grinder. A good rear pad will never do this.
The second issue is friction coefficient. What pads do you currently have front & rear?
The third issue may be air in the system. Make sure the beeld is done properly.
You always get a big front/rear temp differential. See the photo. You can check the rotor temps with a thermocouple or with thermo paint.
Edited by djr81
to answer what gear i'm running...
stock, stock, stock...aaaannnd yep... stock. Everything is OEM Nissan.
I have NO IDEA whether brake fluid was done during compliance. So that was at least the first step i'm going to do with the Motul RBF600 i just bought....
  • 6 months later...
I believe i have the same problem. I discovered that i could stall up more on the h-brake than the foot brake ! To me thats crazy... (auto sedan) EBC reds front and EBC Greens rear.
I just this weekend, machined rotors, resurfaced pads and bled the lines, and there still weak. Rear pistons can be slid in with your hand so there not seized in any way......
Reds were 3/4 gone, and the greens looked almost new from the track days.
My concern is i need them to bite from cold, stationary so i can stall up properly for the drags..
The only thing i have left to consider is either pad type or rear bias valve .... looks to be the large hex nut extension on the master, that the rear lines screw into,
Anyone EVER have dramas with this valve ?
Gary
one place did mention to me that the Skylines have very little rear bias anyway, which could explain it... but i have no idea about the veracity of such a claim...
the bias valve maybe a good place to start
Yeah i think thats my best bet to try to replace that valve with something adjustable to find the best bias that works..... very sparse info out there on this sbuject (re R33's )...
Gary
I played around with front and rear compounds a lot on my upgraded brake set-up (CSC 4 pots 355mm, 343mm single pot).
I ended up going a fairly high temp/high performance pad on the front (Pagid RS 14 "black") and a low temp pad with a high initial "bite" on the rear (Pagid 4-2 "blue" ).
This helped balance out the braking a lot, but as djr81 says, the front bias is considerably more than the rear from factory. As a point in case I expect to go through at least 3 sets of rotors/pads for every set on the rear.
  • 1 month later...
Hey AboBob, can you have a look at your brake master and see if it has the large hex 'nut' (bout an inch long) that the rear lines screw into, and it screw into the master cylinder. Pretty sure this is the rear bias valve.
Wonder if the R34 has more rear bias, it might be possible to swap my R33 one for an R34 one to try out.....
Also heard one of the silvias (poss S15) uses alot more and is able to swap into R33...... so little info out there.
Gary
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
