NYTSKY Posted March 6, 2008 Share Posted March 6, 2008 Hi all, I will be having my engine rebuilt with all the goodies and i have a question on CR. What would be the average amount of material shaved off both the head and the block. 4 thou off each?? When the head and block gets shaved,so as the gasket can seal correctly,will my CR rise alot? I have ordered CP pistons at 9.0:1 CR (stock RB25 CR) and a 1.2mm Cometic headgasket (stock thickness) CHEERS Link to comment https://www.sau.com.au/forums/topic/209294-compression-ratios/ Share on other sites More sharing options...
The Mafia Posted March 6, 2008 Share Posted March 6, 2008 well, you have no choice but to get them done just enough so they are flat. So just do that and then do a mock build and measure it? Depends how good you want it to be. You could end up with 9.1:1 maybe, but thats a good thing I say. Link to comment https://www.sau.com.au/forums/topic/209294-compression-ratios/#findComment-3700875 Share on other sites More sharing options...
Guilt-Toy Posted March 7, 2008 Share Posted March 7, 2008 use a cometic 3 layer head gasket that will bring it down a little Link to comment https://www.sau.com.au/forums/topic/209294-compression-ratios/#findComment-3701585 Share on other sites More sharing options...
RB30-POWER Posted March 7, 2008 Share Posted March 7, 2008 was interesting to read old mate post the other day, that he had to remove the head again to fit a thicker gasket after a rebuild on rb25 because the engine was detonating and not able to make the power it was previously. was well over 500hp or so from memory, thread is on here somewhere. depends on what power you want and what fuel you plan to use i suppose. but the average build/engine will not have a problem at all with such a little increase in cr. Link to comment https://www.sau.com.au/forums/topic/209294-compression-ratios/#findComment-3702591 Share on other sites More sharing options...
NYTSKY Posted March 7, 2008 Author Share Posted March 7, 2008 use a cometic 3 layer head gasket that will bring it down a little The Cometic gasket i will be using is a MLS 3 layer metal type.Maybe i should have ordered the 1.3mm instead??? Link to comment https://www.sau.com.au/forums/topic/209294-compression-ratios/#findComment-3702853 Share on other sites More sharing options...
Risking Posted March 7, 2008 Share Posted March 7, 2008 (edited) run it around 9.2-9.3. the results will all come from whoever you choose to tune it but. sammy will only take off what needs to be taken. Id say dont deck the block unless it needs to be. You need to have this engine put together and measured correctly. It needs to have the squish bands etc all measured as well and piston to valve clearances set properly. Several mock up assemblies will be needed to get it all correct. Edited March 7, 2008 by Risking Link to comment https://www.sau.com.au/forums/topic/209294-compression-ratios/#findComment-3702996 Share on other sites More sharing options...
NYTSKY Posted March 7, 2008 Author Share Posted March 7, 2008 run it around 9.2-9.3.the results will all come from whoever you choose to tune it but. sammy will only take off what needs to be taken. Id say dont deck the block unless it needs to be. You need to have this engine put together and measured correctly. It needs to have the squish bands etc all measured as well and piston to valve clearances set properly. Several mock up assemblies will be needed to get it all correct. Want to make a couple of extra dollars Brad?? With the amount of goodies going into this motor i want it done correctly. Link to comment https://www.sau.com.au/forums/topic/209294-compression-ratios/#findComment-3703008 Share on other sites More sharing options...
Risking Posted March 7, 2008 Share Posted March 7, 2008 if sammy is machining it all up there is no problem with me showing you how to do it. Better you learn whats involved rather than paying someone to wack together an engine. Next time I meet up with you tell me exactly whats being done and will go from there. Link to comment https://www.sau.com.au/forums/topic/209294-compression-ratios/#findComment-3703026 Share on other sites More sharing options...
