Hey guys,
Just after a bit of advice for a turbo upgrade on an rb20. Looking at either a KKR 430 or Garrett 2871. I know the KKR is about half the price of the 2871, just wondering if it would be worth spending the extra on the 2871.
Will have the normal mods, 550cc injectors, 040 pump, front mount, full 3" zorst, PFC or similar, intake, etc.
Just after a bit of advice on what to do.
Cheers
https://www.sau.com.au/forums/topic/209302-rb20-turbo-choices/
best bang for buck is probably an RB25 turbo. past that maybe an HKS 2530 or similar.
yeah already have a rb25 turbo, looking for a fair bit bigger, high mount set up. Looking for 220-250kw...
From memory the 2871 doesn't come in a t3 flange only a t2 which means you will need an adapter plate from t2 to t3 which is a little bit more stuffing around
Better off going a GT28RS, GT2530 or even a GT2535 which is slightly larger
Since your going the bigger injectors, stand-alone ECU etc etc I probably wouldn't go with an RB25 turbo, something bigger and that will make more power will be better suitable
If your looking for a budget upgrade, something up to about 190rwkw then go the RB25 turbo
Horsepowerinabox.com have just brought out a GT2871 with t3 flange and rb20/rb25 six bolt dump pipe flange, for a direct bolt on fit, which is the turbo im looking at, bit exe tho at $1850...
If you are going high mount then don't worry about the flange on the turbo...you can get a high mount manifold with a t2 flange if need be...dump pipe will most likely need to be custom anyway also so i wouldn't worry about that...
However...there is no point in high mounting a kkr430 or even the 2871...keep it low mount if these are your choices...
you can get your rb25 rear housing machined to suit the 2871 and bolt up instandard position.
if you're going highmount, go big if you're going a 2871 or kkr go low and keep it lookin standard.
also internally gated turbo highmounted = very gay imo
wats kkr???? :D
im also looking at options for a bigger turbo udgrade in the future. the T2 flange means you cant bolt the turbo onto the RB20 ex mainifold?
sorry not too sure about this stuff :nyaanyaa:
Yep T2 flange means no for RB20/25
You need a T3 flanged turbo to bolt on to the standard manifold
KKR turbos: http://www.otomoto.com.au/kkr/turbos/index.html
It goes against the grain but possibly a GT2860RS or a GT2871R in a reprofiled RB25 turbine housing would be reasonably easy and cost effective .
Someone on this forum a while back had a non IW real GT3071R on an RB20 and he felt it was ok though these days you'd used the GT30 0.63 A/R IW housing for convenience sake . Its a fair bit of turbo for a 2L six so may be a bit laggy for some .
A .
cheers abu,
i heard that most turbo's up from the RB25 hi flow wont spool up quick enough. When buying a turbo for the RB20 how u can tell if it will spool up fast enough?
Well...you search...because too many of us had the same question as you and there are heaps of threads about this already...
the reality is, if you want 220 + rwkw, you're going to have lag, an RB20 needs at least 4000 rpm on board to start pulling. some like this, some dont, if you dont then stick with 200 rwkw and run a smaller turbo which will give you more midrange punch for the sake of 20-30 rwkw up top
lag = fine, as long as it makes the power at some revs i dont mind, 3071r is looking the goods. Cams be a good investment if i was going to run a turbo like that?
    • If you are fine with China turbos, Maxpeedingrods makes a bolt on turbo. Ive had mine for two summers now and it seems to be holding up ok.
    • Howdy all Im in a little predicament and wondering what everyone’s thoughts are? I’ve had my long block rebuilt and am in the market for a turbo due to my old one having metal shavings from crank bearings (cause of rebuild) go throughout the turbos oil lines and there wheel has a little play. I’m not really aiming for any power, just trying to keep it as oem as possible, but I can’t find a turbo that’s built for the stock ecu or find something that would be a standard replacement. Anyone have any ideas or suggestions
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
