Just Jap Racing, Australia's biggest Intercooler dealer, is proud to continue bringing SAU forum members the very best deals on the biggest range of intercoolers and kits in the country.
We are delighted to announce the arrival of the latest addition to our massive Cooling-Pro range, the Cooling-Pro Stealth Intercooler Kit
Responding to customer demands for a direct fit Intercooler Kit, we bring you the Stealth. The Stealth kit offers the performance and quality our customers have come to expect with Cooling-Pro products, along with simple fitment, and no inner guard cutting, or additional engine bay piping required.
Like similar Japanese kits from the likes of ARC and Blitz, the Cooling-Pro Stealth Kit is designed to fit straight up while allowing you to maintain a factory looking engine bay.
Proven in various applications including street, drift and circuit, the Cooling-Pro Intercoolers uses a high performance 100% vaccum brazed bar and plate core, with polished TIG welded end tanks crafted in 6061 aluminium.
PRODUCT SPECIFICATIONS:
- Super efficient Square Tube & Fin Core, capable of flowing up to 1020 CFM
- Low pressure drop across the core - Approximately 0.2% at 15 PSI
- Beaded and rolled end tanks to ensure piping and joiners stay firmly attached
- Core Size of 600 x 240 x 60mm
- 2.5 Inch Outlets
COOLING-PRO STEALTH INTERCOOLER KIT CONTENTS:
- Cooling-Pro Stealth Type Square Tube & Fin Core (High Efficiency)
- Super strength JJR silicon joiners
- Race quality stainless hose clamps
- Mounting brackets, nuts & bolts (Where required)
Each kit includes a 12 month replacement warranty and Australia wide delivery is also available
We have the Cooling-Pro Stealth Kits in stock, ready for immediate pickup & dispatch, so unlike other deals floating around the net, there is:
1. No deposit required
2. No minimum order
3. No waiting
4. Easy online payment options
5. No surprises
Deal with an established and trusted company! - Not a backyard trader
COOLING-PRO STEALTH INTERCOOLER KIT - $550.00
AVAILABLE NOW TO SUIT:
- Nissan Skyline R32 GTS-T (RB20DET)
- Nissan Skyline R33 GTS-T (RB25DET)
- Nissan Skyline R34 GTT (RB25DET)
- Nissan Stagea WGNC34 (RB25DET)
HOW CAN YOU PLACE YOUR ORDER?
The answer is simple!
Purchase your new Stealth Intercooler Kit online now via our massive new website at http://www.justjap.com for fast Australia-wide delivery.
With Australia's biggest range of High Performance Japanese Parts all under one roof, and all available online, purchasing your tuning parts online couldn't be easier!
Please contact our sales team if you have any questions, or reply here.
Does it require triming on stock Series 2 front bars steve?
Or should i ask if it fits series 2.. ta
You may require some slight trimming, depending on the bar - This is common on any aftermarket intercooler kit :)
Cheers,
Steve
  • 3 weeks later...
if we want to pick up can we just mention the deal on the forums to get the same price you selling at?
Hi mate, thats correct!
Drop in anytime and my staff will look after you.
Cheers,
Steve
hey mate if i brought this kit say today when would i recieve this in the mail??? say 2 days?
Hi mate, that depends on the payment method you select, and your location.
Regards,
Steve
Regards,
Steve
bank deposit commonwealth and in victoria
  • 1 month later...
Stealth Series Intercooler Kits for HCR32 are due back in stock shortly.
Thanks for all the orders guys, keep them coming.
Cheers,
Steve
  • 3 months later...
More stock now available :)
Cooling-Pro Stealth Kits now available off the shelf to suit Stagea WGNC34
Cheers,
Steve
  • 1 month later...
  • 3 weeks later...
for a R34 GTT with post to Perth, how many days and how much is postage?
Hi mate, delivery time is usually around 3-4 business days to WA and postage will be $40.00
Cheers,
Steve
Gday do you guys do installs on these also? if so how much would I be looking at for a R32 GTST?
Thanks
Hi Dave, we certainly do.
Please give us a call in store and speak with Darron and he will be only too happy to do and installation quote for you and confirm when we could book your car in.
Regards,
Steve
Hi,
Would this suit a Series 2 (RB25DET NEO) '00 Stagea without chopping anything? If so, would you have any photos of what one would look like with cooler fitted?
Thanks
    • I had absolutely no symptoms whatsoever that anything was wrong.... I'm very happy it was all spotto'd and re-bled and re-torqued and aligned though. Will be picking it up tomorrow and undoubtedly be like "Oh, that clunk is gone" "Oh, the car really wants to drive straight" "Oh, that pedal feels better" "Oh, it feels like I've gained 25hp" "Oh, the handbrake works now" It should have been a sign that the new Project Mu shoes had 3mm of pad depth on them out of the box, and the OEM ones from 25 years ago that we took out also had 3mm of pad depth, implying the issue was not, and never was the shoes, but we put that down to it not being adjusted correctly. It wasn't, but it wasn't even adjustable at all given one side was boned and the T Junction of the cables was on a 45 degree angle, the non-working side being the one on the massive angle. Obviously when I had adjusted it and reset it and re-tensioned it I had either got it stuck or something along those lines. Oh well. Live and learn and absolutely could have been catastrophically worse so I'm rationalizing it as a win, kinda. I also got the chance to measure the distance between rear rim and the suspension arm/shocks and found a 30mm rubber block only just doesn't fit there. Which is great to know before ordering wheels, when I assumed 30mm was easy. The man with the Porsche adapters has rims that use 23.9mm of that space, so it's safe to assume I have between 23.9 and 29.9mm of space there to play with on the inside. The wheels looked pretty stupidly pokey with the 20mm spacers on the rear, only for me to find that the studs come out another 12mm and the wheel doesn't actually sit flush with the hub because you're supposed to cut your original studs. The wheels do have cutouts that kinda accomodate it, but not fully. So my 20mm spacer was anywhere between 25mm and 35mm. ~25mm and send it will determine on where the wheels sit with the spacers on. When I put the pads in for the track day I will mess around with spacers (with wheels that do not clear studs properly when mounted to spacers) and do more math, for the last time, for the 7th time.
    • Lucky pick up Best to find these things before something horrible happened to the yoke flange thingies I would hate to think what would happen if it dropped the tailshaft  Hopefully the holes are not flogged out in the yokes and it was just the bolts that got munted  As for the hand brake.....ouch, look like the disc got rather hot, and I assume smokey, I recall when I had a front caliper seize on the Commodore, there was lots of smoke and the disc was glowing cherry red when I was able to eventually stop and have a look, and stopping a big heavy car, going down a big hill with some rather high RPM down shifts and some hand brake action is something that makes you think hard about life
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that one side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
