When stationary/slow....yes. When going fast, no. High pressure builds at the base of the windscreen and will either inhibit or reverse the flow.
Does raising the back of the bonnet actually work? So much conflicting information.
It will, you're nearly there. Home straight and all that.
Here's the gore: The above photo was me literally at a paint shop thinking "ah, I can't get it painted like that" Below is the left side vs right side taken randomly with phone. This is after. I now have a GTR strut brace because the vents actually foul on the GTT strut brace. They also look like they very nearly foul on the GTR strut brace, but it's like 35-40mm lower so that isn't possible, lol. I will say this though, the vents let out a LOT of heat when the thing is idling. You could literally see the heat haze in a wall just flowing out of the vents when the car was parked, so the theory about it letting under bonnet temps out when stopped is sound. Though if I had my time again, I would have just cut these out (or just bought GTR bits and cut these out of a GTR bonnet). This photo *before* the whole lot was covered with Carbuilders insulation mat which probably didn't help. Would have looked similar to the below, but in the pattern of the above. I'm sure you understand. Or I could have just raised the back of the bonnet. TL;DR
