I have a stocker r33 gts25t with a nismo muffler. Now i know that the Power FC will work out of the box on a standard ECR33. 10mins initialisationfor idling, 10mins initialisation with aircon on, 10mins initialisation with dehulidifier on then the idle initialisation is complete. Now when i take it out for a drive, stepping on the accelerator makes a weird small noise from the engine. I cant make out what it is, possibility knocking, or hunting (whateter that means lol). The original oem ecu doesn't cause that noise. May i know or does anyone ever encountered that problem before. I took the Power FC out and back to oem afraid that it it is knocking, then my engine would be dead in a few days time. lol
Btw, i did do a full reset before i did the 30mins idle initialisation.
https://www.sau.com.au/forums/topic/209334-apexi-power-fc-slight-problem/
Dude, I believe aftermarket ECU's from japan that come with ignition maps are based around using 100 octane fuel (readily available in japan)- if this is so just plugging it in and driving you'll have too much ignition advance (unless you have 100 octane fuel available?)and it's gonna ping=engine rebuild. Last time I checked a decent tune was cheaper than an engine build. If you bought the thing make use of it and get it tuned on a dyno, and do fill up with the highest octane fuel you can (readily!)......
Edited by doo doo
Well, fuel is cheap here anyways and my skyline uses RON97 Fuel (all the petrol pumps in the country has RON97). I have to replace my coilpacks to splitfires before i go for a tune as my tuner is like 130km away from where i live.
Attached are the readings i had before i pulled out my power fc.
My exhaust manifold is bent and leaking air so that was replaced today.
Edited by teng
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
