What would be a good injector fuel pump setup for this mild turbo on a RB25? Wanting to run around 1 bar boost with remaped factory ecu eventually. Currently i have the factory ecu.
Car is auto and i only want around 220 rwkw for a street car.
I have installed a FMIC, 3" PE2 exhaust and split dump, high flow cat. Splitfire coils. Gt2530 turbo.
Would 550cc injectors be ok for this turbo?
What fuel pump?
Please help me out.
https://www.sau.com.au/forums/topic/209335-injectors-and-fuel-pump-options/
I have a set of 555cc Nismo injectors if you want them.Direct drop in.They have been used for about 7000k and are in perfect condition.
Looking for $550 delivered.
I have a Nismo fuel pump in my car.Cant got wrong with those items.
anyone?
Didn't someone already reply?
As he said, 555 would easily do the job.
I have the s15's too running a hks 2535 on RB25. no probs.
(although for $550? go for that!)
Fuel pump? There's heaps of options, just do a search on the many Bosche/nismo/tomei options
Nismo and Tomei cost a little more but so much less muckin around.
s15 480cc will do the job and cheaper than NISMO 550cc
If you want to spend the cash then get the NISMO 550cc
^ both will be sufficient
If you want to spend the cash then a NISMO or TOMEI replacement fuel pump will drop straight in
If your happy to go with a cheaper pump then a WALBRO will also drop straight in
or a BOSCH 040 if you don't mind cutting the fuel pump cradle
Stock injectors should handle that much power with the factory regulator, if not get a hold of an aftermarket fuel pressure regulator and make sure you've got a pump that'll flow enough. They shouldn't need much more pressure at 1 bar. A lot cheaper than new injectors (unless you can find s15 injectors cheaply).
A walbro will be fine, just make sure you get the 'high pressure' version.
Edited by govich
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
