I'm upgrading my braking system as the old R30 shit ain't cutting the mustard anymore.
Probably going with Z32 4 spots up front and 2's in the rear and quiet possibly using R31 bits to mount the calipars on.... BUT... here's my issue -
The 3 piece alloy work rims i have won't fit anything bigger under them as they are 15inchers so i'll need something bigger and i need some advice.
I'll be going up to some 17inch rims to suit the car, but, offset and stud pattern are holding me up......
Would like to go to a nice common offset and stud pattern to make finding rims a little easier other wise i'll get some made up.
So any tips on my project????
https://www.sau.com.au/forums/topic/209343-r30-brake-and-wheel-upgrade/
My car runs a 17" x 9" with a +35 offset with a 20mm spacer and they sit pretty much just in the gaurds with a touch of camber with r33 brakes (which are probably a bit of over kill and too heavy, in need of a down grade). I don't have any pics here on my work computer but I know I have post them up a few times on here before.
It is possible to fit those 4 pots brakes under 15's my mate bluey runs r33 brakes under a 15" with a 3mm spacer for just enough clearance.
if you put s13 hubs on the fron with coilovers then throw on some big discs and calipars. Then any rims
that fit silvias and 180sx's (over 15in) should fit.
Im in the process of fitting 32GTR discs and calipars to the front. Havent had a look at the rears but i do
have the rear 2pots to go on also. Not sure about rear mounting points and hand brake cable assembly yet..
Are 32 GTR bigger than Z32's?? might be a bit of over kill don't you think?? it's still a light car..
thes work rims have a pretty unusual offset (can't remeber what they are) and will pretty much only fit an R30 import. Plus they have a raised centre in the wheel which barely clears the standards brakes so i'm going to have to get bigger rims
Thats wrong, cause im using silvia rims on my car with silvia rotors and its doesn't clear them and im running a 17x7...Had to get a 25mm spacer for the front
I think they may be slightly bigger and slightly thicker.
Only using the 32 parts coz i got them cheap, so im not worried about overkill.
I said they SHOULD fit not that they WILL fit.
At the moment i have silvia rotors and calipars sitting under 15in silvia rims.
What silvia rims are 17x7??
So whats the largest wheel width and tyre size that will comfortably fit under the guards without flaring the guards or going too deep into the wheel arch?
I run a 17" x 10" on the rear, 17" x 9" on the front. Only have lipped rear gaurds, easy as to do without damaging the paint. No scrubbing anywhere and I run huge steering angle and a fair whack of castor.
Or of course there where these wheels I had for a bit. 15 x 7.5 -10, should have kept them.
a bit of dish is mean thing!! :(
i'm looking at something around 17x8 and 17x9 with a nice bit of dish in the rear
hey dude just run a set of standard r33 gts-t brakes all round
and you will stop on a dime .maye a few mods needed(i have'nt done such a conversion)
but i will i so home work and let you know :(
Alright heres how the situation looks.....
need some wheels first but i'll get that sorted quick enough..
probably going to use r31 front struts in the front and adapt the Z32 calipars to them...(apparently it will be easier) plus i already have R31 shocks in my struts at the moment... we just trimmed a bit off to make them fit.
just had new lower control arms fitted yesterdy.. made a nice differnce in the driving comfort.. but we'll probably ditch them and fabricate some nice adjustable ones down the line so if anyone wants some spanking new controls arms drop me a line... same as the local r30 and at $160 each they're pretty cheap..
anyone got a difference of opion here...? haha i know there will be someone..
Dave
Edited by GTR30
What sorta wheels you after dave?
Something similar to what i already have.. kinda attached to this rims so i'll be sad to see them go.
17inch with a bit of dish to it and 5-7 spoke.. been looking at some work rims that look pretty nice..
see my profile for pics
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
