Hi
We are clean all the old stock out and clean up the garage.
so there is few parts up for sale now.
R34GTR
STD injector x6 $250
STD fuel rail with std fuel regulator $80
STD cam shaft $120
STD Cam gear $50
STD Valve spring $50
STD intercooler $300
STD Exhaust system $500
STD Airbox with snorkel $300
STD BOV with pipe $250
STD clutch $100
STD exhaust system $90
STD front pipe $80
STD cat $ 80
STD radiator $200
ARC radiator $700
STD Rear Bumper $700
STD AFM $460
R33GTR
Nismo O/H twin plate clutch $1700
Head lights $500
Tail shaft $200
STD gearbox $750
AFM $300
Used water pump $50
Used oil pump $100
Passenger seat $500
Front bumper $500
Factory side skirt $200
STD suspension $300
STD cam shaft $100
STD Cam gear $40
STD valve spring $40
STD injector x6 $200
STD Fuel rail with fuel regulator $60
STD bov with pipe $220
STD intercooler pipe $200(got twin turbo on top)
STD exhaust manifold $60
STD front pipe $50
STD cat $30
GTR33 V-spec diff (complete) $500
STD intercooler $280
STD radiator $160
R34GTT
STD exhaust system include cat $180
R34GTT injector $140
R34GTT cam shaft $80
R34GTT intercooler $180
R34GTT rims x3 $300
STD R34 turbo need O/H $150
R33GTST
STD front bumper $100
Boot white $200
STD heater box $150
STD rear spoiler $100
STD side skirt $100
STD suspension $140
STD Airbox $120
STD airbox snorkel $45
STD BOV $30
STD intercooler S2 $130
Tanabe suspension $500
STD fenders(pair) $280
350Z
STD exhaust system (complete) $300
STD suspension $150
S15
STD intercooler $80
STD front brake system (complete) $400
Passenger Fender $200
Supra (JZA80)
STD Auto speedo $100
STD intercooler $100
EVO7
STD suspension $200
STD airbox $100
STD ECU $150
STD tail light $200
STD front bumper $280
MRS
STD head lights $300
STD body kit (full kit) $450
STD engine need O/H $800
Brand new engine done 1500km with head work $2500
MR2
N/A engine $500
Radiator $50
Rx7 (s8 2001)
Bilsten suspension done 5000km $750
STD intercooler $180
STD seats front and rear $900
STD turbo $1400
STD Front brake kit off RS(bigger than S6/S7/RB S8) $1100
STD rear rotors $200
Boot trim complete $250
Roof trim $120
Complete carpet $200
BMW E36 318
STD wheels with tyres 15 inch (near new tyres) $300
Radiator $100
A/C candensor $140
180SX 1.8L
Brand new Trust Intercooler kit $1450
Honda H22A
Complete Engine/Jun cam shaft/Jun cam gear/Jun Valve spring/Jun retainer/Aftermarket head gasket
Botton end need O/H
$3500
used Trust Twin entry intercooler 600x286x75 $500
Jap brand GTR 600x300x100 intercooler $750
please reply to us if you need anything
Thank you very much
Edited by GTAUTO
https://www.sau.com.au/forums/topic/209353-gt-auto-garage-sale/
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
