Anyone can help here?
I'm trying to think which is the best to go for?
Obviously i'm chasing the best response and yet provide with the power i'm chasing.
a Garrett GT2871R with .63 rear housing or
Garrett GT2876 with .86 Rear housing or
Garrett GT30 all with ball bearings
I'm chasing power between 300-330kw at the rear wheels
It's to go on my R33 with RB25DET engine that has:
2mm Cometic head gasket
Tomei heavy duty Valve springs
264 in/ex cams
3.5" exhaust
Walbro 255L pump
WOLF 3D V4 ECU
HKS Boost Controller
38mm Tial External Wastegate
HKS Cast Iron Low Mount manifold
FMIC
Filter
Front Face Plenum with 80mm throttle body
SARD 550cc injectors
Splitfire Ignition
Iridium spark plugs.
GTR Radiator
Adjustable cam gears.
Think of changing my Walbro pump to a Bosch 044 pump with a surge tank instead but i don't know if it's necessary or not, What do you guys think?
Edited by Deceeve
https://www.sau.com.au/forums/topic/209372-need-help-on-turbo-selection-guys/
My choice would be GT3037 .82 run at 22-24psi (as im doing) that way you will have good response and will achieve your power goal.Rather than buying a bigger turbo with more lag. But having that 2mm headgasket it will be a bit doughy down low.
Frankly if you are targeting 300kW as a minimum, you'd do well to head straight to a GT3582.
I noted that your shopping list / parts list includes an external gate, so any of the GT28 series stuff won't be suitable or cut it from a flow viewpoint anyway.
Suggest doing a search, using either GT30, GT35, or 300rwkW as key words for turbo specs. There are a few blokes who have exceeded 300kW but you have to make sure it lives a reasonably long life by giving it the right supporting systems.
I hope your fuel system and engine breathing system is well thought out. If you're actually going to use that power (ie at a track) then cooling (radiator and oil) should be factored in. Get rid of the Walbro, use a Nismo in tank pump.
Keep us posted with updates please, and good luck.
i dunno go the smaller frame turbo and stick the temp probe in a cup of coffee and bob's your uncle. :)
nah, i'm with dale. wringing the neck of GT3076 to get there might be more trouble than it's worth.
Edited by wolverine
Wouldn't the GT2871R white achieve around 300rwkw with very minimal lag especially with the 2mm head gasket?
if running the GT3037 .82 what RPM does the boost comes on and when do you actually hits full boost though?
Is the mods in your car much different to mind?
I'm just not sure how early i can get the turbo to come on boost early enough with the thicker head gasket you see and yet still achieve the goal.
With the 3037 id imagine (in my car) i would see full boost (22psi) by 3800rpm,but i will have a Greddy plenum,cams and an aftermarket exhaust manifold.So might be a little later in your application.
I've already got that mods in my car and is now using the Hyper Gear TR44 and turbo seems to be surging. It comes on boost like so late of about 3500RPM with not even enough G-force and then just die so fast at about 6000RPM. Giving me no power to play with at all.
Not going to be using it on the track just weekend car for cruising or something. With the mods i have wouldn't the GT30 or GT35 makes it alittle too laggy especially with the 2mm thick gasket?
I was thinking of going for the new Turbonetics T62-1 Dual ceramic ball bearing and it is a patent developed by NASA :)
The walbro pump i have is also an in tank pump but what makes the Nismo one more better?
I forgot to add that my fuel system is a sard 550cc with using Splitfire Ignition and Iridium spark plugs.
Will keep everyone posted on the projects.
So you're saying even with the aftermarket plenum with 264 cams and HKS low mount exhaust and the 2mm head gasket i would expect full boost to hit a little later than 3800RPM?
I'm only after anywhere between 300-330rwkw but is also considering the Turbonectics dual Ceramic Ball bearing turbo it's just that i haven't heard anyone in OZ used it before on a skyline especially since it's just new as well. It's rated at 600HP with .63 rear housing.
Mate the 2871 wont even come into the ballpark. Turbo homework you need :)
Max of around 250rwkw on a good day.
Simply put, 300rwkw you ain't going to see anything resembling "response" until after 4000rpm, 4200-4400 is more likely.
And on a stocker motor, GT35, your gonna be limited with RPM range upto 7500 at the most being I wouldn't go much further without uprated rod bolts in the bottom end more so than the coin you spent on the head as the bottom end is the more critical part of it IMO
Mate the 2871 wont even come into the ballpark. Turbo homework you need :laugh:
So in your ipinion with the mods what do you think the best turbo to get that power?
That is crap.
It will not make that much power, and if it did, it would have the engine on the brink of destruction.
Either that, or you like using happy dynos.
Darrens S14 drift car is an example. As for Alberts S15 making 280rwkw on 15psi with another. I'm not talkin the T2 flanged butcher special either. Theres no reason why a T3 flanged GT3071R cannot make that sort of power, altho it will be stretching its legs. A quick read thru a thread just below this turns up;
http://www.skylinesaustralia.com/forums/30....html&st=20
290rwkw with a cropped version! Well then 300 should be no probs with an unmolested GT3071.
Edited by Busky2k
its true... mine cranked 290 rwkw the other day with a cropped 3071R, and 1.2 bar boost to do it. i was making 265 rwkw on 1.2 bar, then chucked some cams in it and now its making more power on same boost.
the 3071R is an awesome all round tuerbo for response and power... they will make 300 rwkw, but not anything massive over that.
I wouldn't mind seeing some of these dyno sheets so I can see just how much the dyno operator has fudged the final power readout.
I have a 3076 with water methanol injection - and it struggles to make 310rwkw on 18psi of boost.
How could a smaller turbo make it just as easy?
there are examples of some extreme results both high and low for any given turbo. given a choice i would shoot for lower peak power output and go a smaller framed turbo every time but this is dependent on use hence it is a personal choice.
simon-R32 has an amazing result out of the GCG cropped 3071 turbo. i am aware of a workshop has struggled to make power with another example of the same turbo. since GCG are highly reputable it is a real headscratcher why one is shooting the lights out and another hasn't gone close. i would have expected simons to top out closer to 270-280rwkw with cams and the great response with the extra care in the tuning and setup.
if 330rwkw is the target i still reckon GT3582
Edited by wolverine
why do you want 300 - 330rwkw's?
does that sound like a nice figure?
personally i would choose a .82 gt3582r but expect full boost around 4000 - 4200rpm
pull hard to 8k happily make 300-350kws depending on boost.
gt30 is at the end of its chain working that hard, and is the same price as the gt35 so why stretch it when you can do it easily.
my gt3582r-iw, with a high stall auto, is still managing 320rwkw on 23psi and no
knock, on shell v power.
my old gt3071 with the auto was out of puff around the 270kw mark
and remember to be prepared for a $10k rebuild either way at those figures.
The reason i'm aiming for that figures is that i'm still running on stock bottom end and i believe that's the safe figures i can push it to for the R33.
I think the GT3582R would offers that power but don't you think with my 2mm head gasket it would be pretty damn laggy?
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
    • Nice, let me know how you find the 98 tune
