i will happily post dyno charts, getting it re tuned very soon with cam gears, so expect less peak power and more midrange as that is what im after since its a drift car. My tuner and the workshoo which has the dyno is extremely reputable in Adelaide, with what is regarded as the most accurate (read, not happy) dyno in the state.
in no way are figures fudged, and the fact is im not even after peak power... my tuner has the whole time been trying to gain more midrange torque (which was also the idea of cams.. but that was a slight step backwards with stock gears)
in my opinion... the 3071R does everything the 3076 r does.. but spools earlier.ll... it is the best all round turbo. for me it was never about the numbers. but rather the response and torque
Well i'm still doing research still and i guess from what you guys telling i gotta rule out GT2871R.
i mean i'm after both response and torque as well but yet still trying to achieve that power range.
Anyway still left on the priority is the Turbonetics T62-1 Ceramic Ball bearing rated at 600HP with .63 housing. follow by the GT3071R and the GT3582R which i'm quite concern that it will be very laggy.
If only we have a few people running the the T62-1 from Turbonetics with similar mods to mine would be awsome to see the result.
though i might ended up testing it out anyway as it sounded quite promising yet more research for me.
The reason i'm aiming for that figures is that i'm still running on stock bottom end and i believe that's the safe figures i can push it to for the R33.
I think the GT3582R would offers that power but don't you think with my 2mm head gasket it would be pretty damn laggy?
your miss informed if you think your bottom end will be safe at 300 - 330kws
mine on a good tune broke ringlands at 265kws with the 3071.
on a motor that only had 35k klms .
so what makes you think your motor is any better?
bolt the gt3582 on and when the bottom end lets go then you can change head gasketsto something more sensible
simon, i was trying to point out some people make the upper range of the turbo's capability and others make a lower range be it due to skill and care with setup or luck of the draw (with hardware).
great job so far by you and your workshop.
pm sent.
Edited by wolverine
    • I'm so far behind in the jobs I have to do at both work and home (including car) that I have become immortal. There's simply no way that I can die now.
    • Each to their own I guess  Me, I put just as much time into cleaning inside of the cars as I do on the outside As for getting wet, it is really no different than steam cleaning the carpets at home, apart from the cars carpet dries alot faster than the house, again, I only do it in the hotter months and leave the car opened up for a few hours As I only do it yearly, it is just before I do the diff and gearbox service, so I clean the carpets, then it's up on stands, wheels off, service, clean the undercarriage,  grease the bushings and do a nut and bolt check on everything  Disclaimer: I typically had all the time in the world to kill when I was working 馃ぃ, so spending a full day or 2 cleaning, serving and "looking at stuff" was,  easily achievable, and a fun mental therapy day As for time to kill, I retired last Wednesday, so apart from my physical training, my days are filled with lots of random jobs around the house and garden...."Idle hands are the Devils something something" I am also buying a new house sooner rather than later, I'm actually looking at a potential property tomorrow, I'm looking forward to getting a car hoist as I'm starting to get to old to crawl around under a car, I can only imagine all the undercarriage cleaning and looking at stuff when that gets set up
    • Yeah, I'm not interested in wetting the carpets, and I don't care about brown dirt/dust that lives deep in the pile or underneath. It's not like I crawl around on them in my birthday suit or eat dropped food off them (because there is never any open food in my car). The seats are alcantara (cheap Chinese imitation alcantara, to be sure!) with barely 1" of foam pad behind the surface. That's not getting wet either. Any car that I would be happy to get the interior wet, I would not care to put the effort into.
    • We have one that holds 2.8L of water. On floor carpet that hasn't been touched in 2 or 3 years, will take a minimum of 2 fills of the tank to do a bedroom, and that's going AROUND the bed.   In the cruiser, I used an ENTIRE 2.8L tank, just on the front passenger footwell. But it had some fungus growing, and had been full of mud from being used as a 4WD for many years. I can do that floor again, and it will still pull mud out. However, the water now only looks dirty, not pitch black and leaving full sludge in the bottom of the tank it sucks back into. Oh, and, this is about a $1500 unit.
    • This is mine, works a treat for the cars, suction is good, I use the Bissell clean and protect stuff I have found giving it a good spray and light scrub with the soft brush on the head of the nossle for carpet, and a rub with a microfibre for cloth seats and cloth door trims, prior to another quick spray before vacuuming it up works the best @GTSBoy You would surprised on what it gets out of carpet and seats that actually "look" clean, I recommend that you test drive yours when you have a little time to kill, then post pics of the muddy looking water that I believe you will find
