Hi,
I got a 3inch highflow cat with no flanges from a seller off the forum, I spent most of the morning ringing exhaust shops to get flanges fitted, quotes were $70 to $100.
I found one for $50.
When I got there he said he had only one 3 inch flange and that he could use the flanges off the compliance cat, so I let him use them.
However he said he couldn't fit the temperature bung because I had to have the part for him, probably from Nissan.
What does the temperature bung do on the cat? Do I need it?
And where can I get it from in South Eastern suburbs, Victoria?
Regards,
Gareth
Temp sensor, ignore it.
So leave it hanging there so to speak? (I'll tie it up to something but it just won't be in the cat :laugh:.
From a quick read of the threads (searched for cat temperature bung and found nothing) its just used to warn you when the air in the cat is too hot?
Thanks for your help as always :down:
Regards,
Gareth
Correct, the surface area increasing matrix inside the cat (be it normal ceramic or metal) has a coating that provides a multi stage chemical converting process.
The process creates more heat after the cat then before (why road side RTA can use laser temp guns to make sure you cat hasn't been "gutted"
The sensor will trigger a lamp on the dash if it rises above a preset. This indicates either to lean mixtures at cruise (hot chamber mixtures), way too rich, and the fuel is burning in the dump pipe, or a blocked cat.
So tie it somewhere, or just cut it off and remove lamp bulb in the dash.
Glad to help
Reading material if your interested
Edited by GeeTR
Thanks but to make things harder, the person who removed the flanges added some of the old cat to the new cat.
Its now about 3cm too long to even fit in! :laugh:
So now I can't drive the car until Tuesday while I wait for this guy to get back to work, and I have to take time off work so he can fix it.
your compliance flanges are probably smaller than 3 inch, most likely 2.25inch, which means you have created a restriction that shouldnt be there.
this exhaust place sounds dodgy.
Well I have a 3 inch exhaust so they probably put some larger flanges on to attach to the exhaust :)
The exhaust place I went to was VERY dodgy. The welds were also low quality so I'm hoping to get it properly done now.
The "bad" side does not even have a square weld on it.
Its going to have to be cut and re-welded (properly) on one side.
I might have a quick read of that material later :).
In regard to the bulb in the dash why remove it?
I mean if I have the sensor tucked away, then its not going to get really hot and go off is it?
And if it does which light informs you that the cat is too hot?
Or is it just a function of the power FC?
Regards,
Gareth
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
