10sec passes!!! Ice Performance Cars shine again.
  • Replies 45
Well done Leewah, running 10s is a dream for some of us and you have just prove that it is possible. When the 9s going to be broken into?!? hehe
Must be a mad rush when it is boosting hard. Would love to see your car on the road some day.
HAPPY DRAGGING!!
