10sec passes!!! Ice Performance Cars shine again.
  • Replies 45
I am pretty sure I recorded that fireball on JET-33's vid camera - [understandably I jumped back as it happened] the battery died and couldnt check it at the time - JET whats the verdict and where's my video ?
