can anyone tell me what the name of these rims are?
well thanks for the help, so ive decided i want these rays gram lights.. can you guys please tell me what size and offset i need in these rims to fit my 32gtr? i want them exactly like that.. with that dish an all... and wheres the best place i can buy them from?
Cheers
Edited by 02_FNE
https://www.sau.com.au/forums/topic/209478-whats-the-name-of-these-rims/
I can see quite a few similarities between them. Companies do change designs so they dont infringe copyright.
Either or, they're still not that great. 1 piece, Im guessing poo offsets and widths, and probably a heavy cast wheel.
Went looking for the DSR website, but it seems DSR makes wheels for Jags, not sure if they're the same company.
At any rate, get the Rays wheels. They're porn. :D
1st one on top are not GTC copies...they are SSR D5R...very nice wheel and looks similar to GTCs but with slimmer spoke design.
I stand corrected then. :D:nyaanyaa:
being SSR's they'd have good offsets and widths for standard skyline guards. Being single piece you couldnt expect anything super serious.
Im still not a fan though. I prefer the GT-C's myself.
well i want the Rays... they are the wheels ive decided on..
just gotta find a set for mine.. im ready to buy... cheers for the help..
R31 Drift Pig - as id said to you on the other thread i like those xd9's but these rays are exactly what i was after, black spoke, machined/ or chrome dish... they will fcukin sweet on my white 32 gtr
Edited by 02_FNE
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
    • The log you did with ECU voltage, can you log the other things too like rpm and oil pressure? Need all that info together to compare easily
