can anyone tell me what the name of these rims are?
well thanks for the help, so ive decided i want these rays gram lights.. can you guys please tell me what size and offset i need in these rims to fit my 32gtr? i want them exactly like that.. with that dish an all... and wheres the best place i can buy them from?
Cheers
Edited by 02_FNE
https://www.sau.com.au/forums/topic/209478-whats-the-name-of-these-rims/
I can see quite a few similarities between them. Companies do change designs so they dont infringe copyright.
Either or, they're still not that great. 1 piece, Im guessing poo offsets and widths, and probably a heavy cast wheel.
Went looking for the DSR website, but it seems DSR makes wheels for Jags, not sure if they're the same company.
At any rate, get the Rays wheels. They're porn. :D
1st one on top are not GTC copies...they are SSR D5R...very nice wheel and looks similar to GTCs but with slimmer spoke design.
I stand corrected then. :D:nyaanyaa:
being SSR's they'd have good offsets and widths for standard skyline guards. Being single piece you couldnt expect anything super serious.
Im still not a fan though. I prefer the GT-C's myself.
well i want the Rays... they are the wheels ive decided on..
just gotta find a set for mine.. im ready to buy... cheers for the help..
R31 Drift Pig - as id said to you on the other thread i like those xd9's but these rays are exactly what i was after, black spoke, machined/ or chrome dish... they will fcukin sweet on my white 32 gtr
Edited by 02_FNE
    • Gday, Due to not finding much up to date info on this topic I thought I'd make a thread to get peoples latest opinions/recommendations. Background info -  I've got a S1.5 R33 GTST as a fun project car, mainly for street use and occasional drag strip, apart from all the cosmetic things I'll be doing a full rebuild of the engine with forged internals. Since it'll be getting new cams (kelford) and springs to match I thought I might as well get new lifters and valves while I'm at it, the dash says 160k KMs but the engine seems pretty tired, compression measures about 130psi across all cylinders so I'd like to freshen everything up. This is where I'm tempted to just fork out the extra and go solid lifters while it's all apart, aiming for 400-450kw atw with a flex tune. Assuming all supporting mods (oiling, fuel and all bolt ons) with a lightly ported head and turbo to match (yet to make a decision possibly gtx3582r or similar from Hypergear) I've seen the Tomei kits with just the buckets getting around, Supertech sells most things - Supertech High Performance Cam Followers | Trusted Racing Cam Followers Questions -  Has anyone found the Hydraulic lifters to limit them at this power level? Is it usually found that you can just clean the stock lifters and find they work fine?  Does going solid lifters save any headaches/issues with hydraulic lifters in the future? Any recommendations on other things that will need to be replaced, I know I'll need to get the solid profile cams but can you use the same type of valves and springs/retainers and is it recommended to change the guides and stem seals?    Summary -  Basically looking for pros/cons and wanna know if I'll actually need the extra RPMs from solid lifters or it'll just be bragging rights to say it ReVs OvEr 8000 Cheers
    • Ha ha ha, this stuff they had was installing Toshiba PLCs that were made some time in the 1990s, and they were replacing GEM80 PLCs. To let those two talk (staged upgrade along a ~1.2km long building that was split into 4 sections), was a bunch of WinXP machines running Java gateways... There was no way to put something like ProfiSafe in... Most of the HMI machines were WinXP, with Java program, with a custom button board emulating a keyboard... About the only buttons in the operator stations that went direct to the PLCs was the eStop. There was some interesting design stuff in that place...
    • Stock bypass valves are good for plenty of boost.
    • Check for fuel flow out of the outlet end of the rail. Check for spark. Try to start with aerostart (or pressure can brake cleaner or similar solvent in a car) prayed in through TB. If you have fuel and you have spark and it will fire on substitute fuel, then seriously suspect that E85 sitting for ages in your fuel system has destroyed something and put it in your injectors.
    • Nissan stock oil pressure is typically about 1 bar at 1000 rpm plus about 1 bar per thousand revs on top.
